keep compression at 10.5:1 or change it?
Old Sep 30, 2011 | 01:47 PM
speakerfritz's Avatar
speakerfritz
Default keep compression at 10.5:1 or change it?
Up coming upgrade to 103 on my 07 ultra. Planning on using stock heads which have been MCR and ready to install. 255 CAMs. Obtained some forges SE 10.5:1 pistons. Question is am I on the border of 92 pump gas and detonation issues....should I shoot for 10.25:1 to be safe ? Basically thinking changing gasket size + or - to put me below or under the bar. Thoughts? Mainly looking for low to mid range power...not really looking for the max power I can get at the max RPM the engine can handle.
Old Sep 30, 2011 | 02:16 PM
thenewrage's Avatar
thenewrage
I have 10.5:1 with manual cr's. I run the best gas I can at whatever gas station I'm at. Bike runs great. Once in awhile it has a rough start but 90% of the time it starts fine
Old Sep 30, 2011 | 02:28 PM
'05Train's Avatar
'05Train
The 255 gives you a high CCP, but going with a thicker gasket is going to screw up your squish. With the MCRs you should be fine. Though at that CR I'd strongly consider a different cam.
Old Sep 30, 2011 | 02:32 PM
131tman's Avatar
131tman
255's - comp ratio up to 10:1
Old Sep 30, 2011 | 03:08 PM
speakerfritz
Well, thanks for the info so far. What CAM's are better suited in the low to mid RPM range? Any chance that the volume added as a result of the MCR drilling will lower my compression ratio below 10.5:1. It's a pretty good size hole and even with the MCR's closed, the hole is pretty deep.
Old Sep 30, 2011 | 03:46 PM
'05Train's Avatar
'05Train
If it were me, I'd look at either the Woods 555 or the T-Man 590.
Old Sep 30, 2011 | 04:44 PM
Indianspringsaz's Avatar
Indianspringsaz
Andrews 54 will run great. That is what you need.
Old Sep 30, 2011 | 04:49 PM
Indianspringsaz
Change your plan if you can. Bore the cyl. to 107". Use CP flat top pistons and the 54 cams. CNC the heads now or when money allows. Tried and true combo. Be sure you keep the CCP down at 190 with that Ultra. You will not be happy with pump gas in the combo you are talking about.
Old Sep 30, 2011 | 04:52 PM
Indianspringsaz
delete
Old Sep 30, 2011 | 05:10 PM
speakerfritz
Thanks. If the SE forged pistons will flat out not work....then I think I will just stick with the stock 103 flat tops that come with the stage II kit. I stumbled into the detonation issue at the 255 10.5:1 compression range and thought that if my MCR's added a few CC's ove volume and if I used a custom slightly thicker head gasket, I could stay right below the wire.
