I guess I own a DUD!
Old Oct 1, 2011 | 05:53 PM
mkguitar's Avatar
mkguitar
hmmm, I gotta check out my 09 FLHTC one of these days.
I would wonder if there is a tuning concern with the OP's bike
my 88 FXR has done over 135 a number of times, slightly worked cop motor and a 15% overdrive.
my 95 FLHTC topped at 115.
Wonder what the 09'll do.
any import will go much faster at 1/3 the money
mike
Old Oct 1, 2011 | 06:11 PM
XKnight's Avatar
XKnight
Unless you plan on running it at over 100 MPH on a regular basis I'm not understanding what the issue is. If it runs good at normal speeds that should suffice.
Old Oct 1, 2011 | 06:33 PM
heavymetalthunder's Avatar
heavymetalthunder
sounds like its a stock 88" motor. punch it out to a 95" do a cam and head work it will run better. My 95" ran like a scalded dog. I kinda wish I still had it.
Old Oct 1, 2011 | 06:41 PM
danmo's Avatar
danmo
My 05 Runs up to 100 no problem, been up to 115 too with no problems. Took a little bit but not excessive in my opinion.
Old Oct 1, 2011 | 06:44 PM
speakerfritz's Avatar
speakerfritz
did you disable the speed limit governor.....no wait...thats for lawn mower engines
Old Oct 1, 2011 | 08:16 PM
NoCoLoco's Avatar
NoCoLoco
The problem is, your bike is 5 years old with barely any miles on it! An object at rest tends to stay at rest. But seriously, you might be shifting a little too early. Don't be afraid to twist that throttle and let the RPM's climb before shifting gears. Just a thought.
Old Oct 1, 2011 | 08:21 PM
NoCoLoco's Avatar
NoCoLoco
If you're already in 5th you should downshift if you wanna take it up to 100 real quick.
Old Oct 1, 2011 | 08:30 PM
scasey's Avatar
scasey
I am definetly not afraid to twist the throttle, problem is I actually started to laugh at how gutless it was when I did! My Cobra will do 78mph in 2nd gear. Now I know Harly's are not built for speed and I am fine with that because that is not why I bought it but 100mph is all it got? On a bike? plzzzzzzzzzzzzzzzz......................
Old Oct 1, 2011 | 08:41 PM
blusmbl's Avatar
blusmbl
Sounds like you need to drop another $5k on motor work to get another 10mph out of it. Then it'll be fast.
Old Oct 1, 2011 | 08:46 PM
scasey's Avatar
scasey
