Screaming Eagle stage 2 kits
Old Oct 2, 2011 | 03:13 PM
berniemc's Avatar
berniemc
Default Screaming Eagle stage 2 kits
Will a stage 2 screaming eagle kit for 07 96ci be the same as the kit for 2010 96ci.Harley shows different part numbers and I found a bargain on 1 for 07 model if it will fit my 2010.Only difference I can see is colour of jugs.Thanks
Old Oct 2, 2011 | 03:17 PM
captainron62's Avatar
captainron62
List the part numbers you are looking at and I can tell you. I work at a Dealership and will tell you the exact differences.
Old Oct 2, 2011 | 04:36 PM
berniemc's Avatar
berniemc
part number
29907-07 is for 07 and part number
27557-08 is for 2010.
Old Oct 2, 2011 | 06:34 PM
SE120RG's Avatar
SE120RG
the difference is going to be in the SE air cleaner. the back plates are different because HD changed the size of the TB when they went to the FBW set up. the jugs, pistons, cams will work but the AC from the 07 kit will not fit your bike
Old Oct 2, 2011 | 07:05 PM
speakerfritz's Avatar
speakerfritz
also, some stage II kits do not have CAM bearings....some do....
berniemc
Aug 19, 2015 11:25 AM
liftedmega
Screamin Eagle CVO Models
Jan 16, 2012 05:20 PM
KaponeWKYA
Jun 13, 2010 12:44 PM
kevdog
May 14, 2009 11:26 AM
johngmaur
Apr 17, 2008 07:37 PM
