110 screaming eagle kit for 07 models
Old Apr 7, 2007 | 01:47 PM
johngmaur's Avatar
johngmaur
5th Gear
Default 110 screaming eagle kit for 07 models
has anyone installed the 110 screaming eagle kit for 07 models yet........mines been in the shop for three weeks now......? still having problems with it......
Old Apr 7, 2007 | 02:00 PM
onlythebest's Avatar
onlythebest
Default RE: 110 screaming eagle kit for 07 models
I would like to know how it turns out. All the details when its finished would be nice. Why is it taking them soo long? Does the case have to be split? I am considering this for mine.
Old Apr 7, 2007 | 02:08 PM
UltraKla$$ic's Avatar
UltraKla$$ic
Cases do have to be split. Taking a while to do it is one thing, but having problems is concerning. Maybe waiting on parts?
Old Apr 7, 2007 | 02:32 PM
johngmaur's Avatar
johngmaur
5th Gear
did you have yours done? how does it run?? how long did it take you to get yours back??
Old Apr 7, 2007 | 06:51 PM
Tinkermc's Avatar
Tinkermc
I think after your done you should write the story with pics of course and may even give some prices.
Old Apr 7, 2007 | 07:50 PM
DI_Dave's Avatar
DI_Dave
ORIGINAL: johngmaur
Why did you have the SE Kit done over another BB Kit from the likes of GMR or HQ???
I'm not questioning your choice, just curious as I was going to go with a 107 kit late this year.
I had in mind the 107 + Cams + Heads + etc. Had no intention of splitting the cases (sounds expensive).
From what I understand, the 107 kit is a ripper.
Like I said, just curious. Maybe I haven't looked into this deep enough.
Best of Luck.
Old Apr 7, 2007 | 11:23 PM
110 street glide's Avatar
110 street glide
6th Gear
I had a 110 kit installed in my 07 SG, and it did take a while. the cases do have to be split, and sent
to a machine shop to be bored so that the bigger cylinders will fit.
Old Apr 8, 2007 | 07:34 AM
onlythebest
ORIGINAL: 110 street glide
Can you give us a little more info on your build 110 Street Glide? Did you do it? Dealer? total cost? difference in HP TRQ etc?
Thanks
Old Apr 8, 2007 | 11:14 AM
johngmaur's Avatar
johngmaur
5th Gear
got her home finally yesterday late....was in shop for 18 days... cases had to be split....this is an 07 roadking classic 96ci motor.... that is why i went with the se 110 kit..it does not void my warrenty......rode some yesteday.....very fast ... waiting on the rienheart true duals ...that are on order...kit comes with screaming eagle mufflers....very quiet...
some numbers for parts
got the kit from chicago harley davison......saved almost 500.00 bucks there....price at our harley shop here in charleston sc is 2499.00 chicago has everything 20 percent off...
labor was estimated around 2040.00.....cut um a check yestday for 2240.00 .....it was the first 2007 with the 96 motor they had ever converted to 110.......bike is awesome........i dont know how to post pictures but when i figure it out i will ....thanks for all the great responces..i hope this helped some....ride safe..john g
Old Apr 8, 2007 | 01:54 PM
fastbydrmike's Avatar
fastbydrmike
I had this kit on order for my 07 Ultra and I cancelled it because my mechanic says it is a stroker motor and will not last long. I decided to keep my Ultra stock and change my 05 Dyna motor which is a 88 cubic inch. He says to send my motor up to World Famous Carl and make it a 116 and it will not be a stroker motor. He said it will be very dependable and 120+hp and spin the tire in the first four gears!!!!!
