Arc mini two channel amp issue...gain control problem!
Old Oct 4, 2011 | 06:08 PM
Mixter's Avatar
Mixter
Default Arc mini two channel amp issue...gain control problem!
Hey guys,
Bought the amp second hand. One of the gain controls (white inset button) wore down when I was trying to adjust it. It was pretty deep set in the amp. Now when I try to adjust it won't turn. Are they expensive to fix and who could repair it? An audio shop?
Thanks mickey
Old Oct 4, 2011 | 06:17 PM
mkguitar's Avatar
mkguitar
probably any shop that still repairs electronics--- not many left... BUT the music world still repairs gear rather than replaces, so check for a reference from Steve's or other music store
Rocky Mountain Sound ( concert sound supplier) used to have a great tech who could fix about anything. He had a shop in the front of their business- try calling them.
IF you determine that your "optimal setting"- is all the way up, then it would be easy for a tech to just wire it a jumper and have it at "full" rather than try to get a replacement potentiometer of the same type.
Use the working channel to determine that....that's what I'd do
Mike
Old Oct 4, 2011 | 06:28 PM
Biggzed's Avatar
Biggzed
You could try pulling the cover off and having a look at it. Could be just the cap is bottoming out on something and needs to be "pulled up" a bit.
Zach
JNM3
Audio Systems
19
Apr 26, 2018 02:00 PM
Litewings
Audio Systems
16
Sep 24, 2014 10:25 AM
Mixter
Oct 18, 2011 10:12 AM
Bradley Jones
Aug 15, 2010 08:54 PM
tazman44
Apr 7, 2010 07:50 PM
