Labor costs for cam change
Usually your shop will loan it to you.
Read Atrain68's excellent tutorial, the video Boogaloodude provided, as well as the manual until you're sure you understand every step and are confident enough to do the job. Anyone with moderate mechanical ability and a normal array of tools can do it. The only special tool needed is an inner-bearing removal/installer tool. The Fuel Moto cam-install kit is a bargain at $50 and has the Torrington bearings included.
I told him that was crazy, we did it in my garage in an afternoon.
Keep your work area clean and organized. I set up a bench next to my bike that I cover with heavy paper towels. I lay out the parts that come off the bike on the bench, keeping any gaskets or o-rings with the part when it goes on the bench. I can make notes to myself on the paper towels. I'll keep the front cylinder parts together on one side of the bench, the rear on the other side, and try to lay out the parts in roughly the reverse order they'll be going back on the bike.
Once I've got everything apart and laid out on the bench, I'll clean the area, get my bag of gaskets and o-rings and start putting it back together. If your parts are laid out on the bench in the order they came off the bike, that will help you keep organized as it goes back together. Take your part, compare the old gasket or o-ring with your new ones, that will help you ensure the right o-ring goes back on the bike.
Cleanliness and organization are key to a successful job, in my opinion. Here's a tc88 top end all laid out on my bench, ready to go back together.
I think if you do cam jobs on a regular basis you will master the procedure and sequences, speeding the whole process considerably, but doing it the first time and maybe once every year or two thereafter isn't keeping every detail fresh in you mind. That's the case for me, anyway.
PROPER MEASUREMENTS....LOL that's some funny ****... If you think HD does that...
Get the manual, search the forums, there's a bunch of threads on it.
There's a pretty good video on youtube that goes through the process, start to finish.
http://youtu.be/n5KvamRqCis
