Stereo install help needed - shopping list?
Old Oct 7, 2011 | 01:54 PM
oc357's Avatar
oc357
Default Stereo install help needed - shopping list?
I pieced together a stereo for my 2001 RGU but now have some questions about the small items.
The stereo consists of:
2 PBR 300x4 amps
2 Polk audio db 6x9 in Cycle sound lids
4 Polk audio db6.5 2 in fairing 2 in lowers
2 Polk audio db5.25 in tour pack pods
My questions
Does anyone know of a good weatherproof quick disconnect for the speakers
Which bass blocker should I run on the 5.25's will they fit in the pods with the speakers
Does anyone know of a good multiple amp wiring kit
Can anyone think of something I have forgotten
Thanks to all for the input
Old Oct 7, 2011 | 04:56 PM
omgtkk's Avatar
omgtkk
Good waterproof connectors can be had from either Deutsch or Delphi Weatherpak. JP cycles sells them, but you can get them much cheaper by searching on Ebay. A two terminal Delphi sells for about $3. I just ordered 4 of them for my bike. The factory connectors on your HD are Deutsch. They are more expensive and a bit moree complicated than the Delphi's.
Old Oct 7, 2011 | 06:55 PM
Harleypingman's Avatar
Harleypingman
2 PBR 300x4 amps
4 Polk audio db6.5 2 in fairing (speaker adapter rings?) 2 in lowers (grilles?)
My questions
Does anyone know of a good weatherproof quick disconnect for the speakers (As mentioned previously, Deutsch or Delphi Metrapak)
Which bass blocker should I run on the 5.25's will they fit in the pods with the speakers? (What's a "bass blocker"?)
Good luck with your project.
Carl
Old Oct 8, 2011 | 06:29 AM
oc357's Avatar
oc357
Thanks for the input, I forgot to list that I do have the adapter rings and grilles. I will search for the Delphi connectors today
The Bass Blockers are a passive inline crossover that eliminates certain frequencies. Since I am running the 5.25's and the 6x9's off the same amp I want to eliminate the bass going to them so I don't blow them.
Old Oct 8, 2011 | 08:06 AM
GLACIERPEARL's Avatar
GLACIERPEARL
You didn't mention what head unit you were using.
Old Oct 8, 2011 | 08:32 AM
oc357's Avatar
oc357
I am using the stock head unit for right now.
Old Oct 8, 2011 | 08:35 AM
Harleypingman
For an excellent vendor of Deutsch connectors, and to see the product, try Batts Racing for the DT series Deutsch connectors:
http://www.deutschconnector.com/prod...es_connectors/
For an excellent vendor of Delphi Metripak, and to see the product, try Ballenger Motorsports for the GT 150 series:
http://www.bmotorsports.com/shop/ind...0o3tq0bdt9ohu2
Drag also sells the Deutsch connectors, pins, sockets, etc.
Carl
Old Oct 8, 2011 | 09:43 AM
Harleypingman
FWIW, a buddy installed Polk DXi 6.5" speakers in the tour pak pods--picture attached.
If you'd like to consider using them instead of the 5.25" speakers, send me a PM and I can put you in touch with him.
Carl
PS: Not sure if I got the Polk model number right; they're definitely Polk 6.5's, but they aren't the Db or MM series. Also, you can correct the typo in the first post--you have a 2010 RGU, right?
Attached Thumbnails Stereo install help needed - shopping list?-p7250046.jpg
Old Oct 8, 2011 | 03:24 PM
GLACIERPEARL
*Ouch*
Unless you are planning to replace that,..........save some of your speaker/amp money, because you're wasting your time otherwise.
Old Oct 8, 2011 | 03:31 PM
mkich66225's Avatar
mkich66225
4th Gear
Carl
thanks for the links, I was looking for those
