Trouble
Old Oct 8, 2011 | 12:09 PM
hawg50's Avatar
hawg50
it sounds like you have a bad rubber hose for the rear brakes.they will deteriorate over time and allow the fluid to go only one way.i would replace the hose,flush the old fluid out,refill with fresh and bleed the rear brake system.as for the noise in the primary,did you check the compensator nut on the crank?it could possibly be loose.
Old Oct 8, 2011 | 12:12 PM
hawg50's Avatar
hawg50
i have no idea how my post appears above yours.
Old Oct 8, 2011 | 12:17 PM
1SG FLTC's Avatar
1SG FLTC
Stage II
Default Trouble
Have a question, yesterday while out on my 1985 FLTC the rear brake grabbed, not enough to lock the rear tire but enough to make me stop as was grabbing really hard, after pulling off of the side of the interstate, the rear brake was smoking and the rear tire would no longer roll...after maybe 10 minutes, the pedal goes all the way to the floor with no brake at all and the rear brake released...so am riding it back home and hear this awful clanking in the primary, pulled the inspection plate and see this bolt laying in there, it drops down into the primary and cannot reach it any longer, so this morning pull the primary cover and see where the bolt had came from, replaced and put the primary back together, put oil back into the primary and start it up, now a rattling noise is coming from the front sprocket, or it sounds that way. Any ideas what this new noise could be ? Also go to working on the rear brake, check the fluid first, it was good, check the pedal just for ***** and giggles and now have brakes again, any ideas on this also ? All this in one day
Old Oct 8, 2011 | 02:01 PM
mkguitar's Avatar
mkguitar
rebuild caliper, new hose and fluid, flush the fronts while you are at it.
what was the bolt in the primary for the shoe?
is the shoe worn?
did the bolt get munched by the chain/sprocket?
mike
Old Oct 8, 2011 | 10:16 PM
1SG FLTC's Avatar
1SG FLTC
Stage II
Mike, the bolt get get chewed somewhat, the sprocket looks good. I will pull the promary cover back off tomorrow and check the compensator nut as well to make sure not loose...The bolt was one of them them goes through the primary into the housing for the motor...I will check the chain tension as well, should have done these things before putting it back together
Old Oct 9, 2011 | 02:25 AM
mkguitar's Avatar
mkguitar
just a reminder to disconnect the battery.
it is fairly easy to activate the starter by manipulating the starter gear ( bendix) when the primary cover is off.
when that happens the chain moves and fingers can get plucked off.
position of kill switch or location of key have nothing to do with it.
mike
94fx
Aug 10, 2017 11:39 PM
94fx
General Topics/Tech Tips
Aug 10, 2017 02:26 AM
mtnlvr
EVO
13
Aug 1, 2016 10:52 PM
Keithhu
Aug 27, 2015 03:28 PM
italiano
Feb 26, 2007 08:11 AM
