Does anyone have a PCIII map for an 07 Ultra with a SE air cleaner but stock exhaust.. Can you use the DynaJet one that specifies pipe changes along with the SE AC ?
SteveO
Thanks for the response..
Only ones I see that are close are the following:
m812-000 - Zero map
m812-001 - Stock exhaust, stock Air filter, Stock ECM, Dynojet O2 sensor eliminators installed
I have the Screamin Eagle air filter kit but stock pipes, does it matter ?
m812-003 - Vance and Hines Ovals slip-on exhaust, Screamin' Eagle air filter, Stock ECM, Dynojet O2 sensor eliminators installed
Sure it matters...you'll get much better performance with a map matched to actual components...better yet with a decent exhaust system...optimally tuned on a dyno!
Agree completely that pipes would help performance.. But right now have the SE AC, PCIII and O2 elims with stock pipes.. I need to set it up for that config, soI am trying to locate a map for it
Try 812-007,Screamin' Eagle Touring slip-ons, Screamin' Eagle air filter, Stock ECM, Dynojet O2 sensor eliminators installed, Rev Xtend enabled.
This one uses the se touring mufflers which are 99% the same as stock muffs. Dont worry about The rev extend it has no effect on your setup. This will get you set up as near to your setup as possible with a free map. Best to have it dyno tuned but I bet it runs great with this map.
