2012 SG...No lights No nothing!!!!
Old Oct 9, 2011 | 11:20 PM
KYFATBOB's Avatar
KYFATBOB
Default 2012 SG...No lights No nothing!!!!
So hears the deal, I changed my bars out and as I was slowly putting it back together I thought I had better check to make sure that all of my buttons were working correctly before I put everything back on. Turned the ignition on and nothing...... No dash lights absolutely nothing.... So I went back through everything and verified no pinched wires had tight connections and still nothing, I will admit that I got a little ahead of myself and forgot to pull the main fuse and disconnect the battery. So I thought maybe its hung up somewhere so I pulled the fuse and disconnected the battery and let it sit for a little while, hooked everything back up and still nothing. The whole time the security light was flashing, also after I put the fuse back in and hooked the battery back up I noticed the the security light stayed on for probably 10 minutes without flashing. After 10 minutes it went back to flashing.... Any one experienced this before or have any idea what it could be? I even disconnected the new bars and hooked up the old ones and still had nothing...
Old Oct 9, 2011 | 11:27 PM
KYFATBOB's Avatar
KYFATBOB
Forgot to add I checked all the fuses and they were fine, could it be one of the relays???
Old Oct 10, 2011 | 02:39 AM
jsimanella's Avatar
jsimanella
6th Gear
Hate to ask, but you did "pull" the fuses, to check continuity, right?
Old Oct 10, 2011 | 07:56 AM
KYFATBOB's Avatar
KYFATBOB
no I didnt, and wouldnt you know my battery is dead in meter.....
Old Oct 10, 2011 | 08:56 AM
dbell66253's Avatar
dbell66253
If you pulled the ignition switch to change the bars, are you sure you reinstalled it correctly?
Old Oct 10, 2011 | 08:57 AM
KYFATBOB's Avatar
KYFATBOB
I didnt have to pull it.
Old Oct 10, 2011 | 08:48 PM
KYFATBOB's Avatar
KYFATBOB
Ok so I took everything back apart and still cant find any issues, after researching I have found that a few people have had some issues with a wire coming off of the iginition. Were are the wires to the ignition at????
Srhking247
Mar 29, 2018 12:12 PM
Desperado
Mar 4, 2016 04:59 AM
packrat56
Jan 11, 2016 06:21 AM
roadglider1
2014-2024 Touring Models
Jun 6, 2015 09:07 AM
Down2Ride
May 12, 2011 11:26 AM
