Power commander 3
Old Oct 13, 2011 | 09:30 AM
XtremeHD's Avatar
XtremeHD
Default Power commander 3
If a Power Commander lll loses it map is it at all possible to re-install the correct map and continue, thats if it accepts it???
Curious Dave
Old Oct 13, 2011 | 09:34 AM
ajayrk's Avatar
ajayrk
Yes. How do you know it has lost its map?
Old Oct 13, 2011 | 09:39 AM
XtremeHD's Avatar
XtremeHD
running the bike in PA and then all of sudden the rear cyclinder shut down, and had to unplug PC 3 to get home, was wondering if it could be remapped instead of buying another unit.
Old Oct 13, 2011 | 09:50 AM
paguy's Avatar
paguy
Go to the Power Commander site. Download maps for the PC lll. Find the map that matches your bike. Hope you have the 9volt aux set up to provide power with PC off the bike. If you don't have aux power fitting you will need to reinstall PC lll on bike.
Now if you have a laptop or a real long USB cable, you can always ride the bike up to your desktop, turn power on bike, hook up USB to PCll, download your set up. Don't forget to download ignition table. Good Luck.
Old Oct 13, 2011 | 10:59 AM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
A Power Commander cannot lose it's map, it is written right to the board. If you hook up to the software and it states "no map loaded" it is referring to the software not the PC itself. If it has dropped a cylinder it is likely not a map issue you may have something else going on with either the unit, the connection or otherwise. I would contact Dynojet technical support at 800-992-4993
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
matchstick30
Aug 17, 2014 11:47 AM
albngore
Dec 30, 2011 08:48 AM
PiedPiper
Jul 12, 2009 08:50 AM
bzzrd2
Jul 18, 2008 02:27 PM
anubisss
Mar 8, 2007 10:48 PM
