starting question
Old Oct 13, 2011 | 05:56 PM
toad6301's Avatar
toad6301
I have not done anything with the starter yet, so I doubt
the contact has moved but you never know.
Old Oct 13, 2011 | 06:12 PM
billhawks51's Avatar
billhawks51
Just replaced battery on 09 RKC same symptoms. Battery checked good then it stranded me. I walked off with lights on for about 5 Minutes. Had battery checked again would only charge to 12.3 volts. Replaced battery, starts like new.
Old Oct 13, 2011 | 08:00 PM
toad6301's Avatar
toad6301
Nice to hear another '09 with the same symptoms,
That was my first thought after cleaning the connections. I just checked the bike with a meter and it showed right at 13 volts and then dropped to
10.5 - 11 volts when I hit the start switch. Same thing just kinda hesitated and then started right up.
Old Oct 13, 2011 | 08:18 PM
lionsm13's Avatar
lionsm13
What is a better battery to go with than stock for a replacement to those of you who have or are going to replace their battery? I wonder if the extended warranties cover the batterys, you would think so..
Old Oct 13, 2011 | 08:40 PM
hockey8787's Avatar
hockey8787
My 09' is doing the same thing, sounds fishy!!
Old Oct 13, 2011 | 09:23 PM
SteveO's Avatar
SteveO
Had the same problem on my 08 SE3, thought it was the battery or starter. Believe it or not, it was the stock compensator, it was worn out at just 13,000 miles was hanging up and binding causing a hard start.
Read a thread on this same issue and decided to change to the new SE compensator...............starting problem solved, now starts like a new bike, no more big clunk when it starts, neutral is easier to find easier smoother shifting.
The new SE compensator is a heavier design and has an oil grove inside the case allowing it to spin more freely when starting.
Ms54Coupe
Apr 28, 2013 07:16 PM
robo5555
Feb 8, 2011 08:42 PM
ranger007
General Topics/Tech Tips
Jan 23, 2010 08:26 AM
MJR
Feb 8, 2009 12:25 AM
Onecoldtrip
Apr 13, 2008 08:00 PM
