supertrapp SuperMeg installed 2010 SG
Old Oct 15, 2011 | 09:27 AM
iwillfixthem4u's Avatar
iwillfixthem4u
Default supertrapp SuperMeg installed 2010 SG
Installed Supermeg on my 2010 SG yesterday. now right side front floor board wont fit (hits front pipe). also rear floor board has to be installed one hole higher.. anyone else?
Old Oct 15, 2011 | 02:10 PM
brents180's Avatar
brents180
I can't help you with your floor board questions but I am curious as to what A/C and tuner you are using with the supermeg and how it all compares to stock. Had a supermeg on my wide glide with a pc5 and it was awesome. Thinking of doing that to my rk still.
Old Oct 15, 2011 | 02:52 PM
mkguitar's Avatar
mkguitar
maybe you head over to supertrapp, they have support forums.
I use alot of their products on my bikes, just put some cheap nightsticks on my 09 in place of the supermegs, just to see.
mike
Old Oct 15, 2011 | 04:28 PM
iwillfixthem4u
I'm running the stage one air filter backing plate with a K&N element and have the stage one upload from Harley... runs great! just got back from a ride and checked gas miliage..46.5 MPG.. 5 MPG above my prior Avg. I am running 16 disc's with a closed end cap.
Old Oct 22, 2011 | 10:32 AM
grbrown's Avatar
grbrown
I had minor issues with the fit of my SuperMeg. Took the bike to have it dynoed and he spotted this, also refitted it properly! Fine now. Try again with care!
Old Oct 22, 2011 | 01:10 PM
kmayHD's Avatar
kmayHD
Might just be time for a floorboard extension kit, move the boards 3/4 of an inch outward, clear the pipe, and really shouldnt feel like a drastic change of your positioning.
Old Oct 24, 2011 | 12:55 AM
Huladog's Avatar
Huladog
Default Simple solution!
Ran into the same problem on my 2010 SG with the black SuperMeg. Didn't realize the front header was touching the front floor board mount until after a test ride when I noticed it rubbed off the black coating.
Simple fix is to add a washer or two on the front floor board mounting bolt, it will move the floor board outward just enough to clear the header. Probably won't need to add a washer to the rear mounting bolt.
Then start it up to be sure the vibrating engine doesn't rub the floor board mount anymore.
Aloha,
Huladog
Terminator69
Dec 1, 2012 11:30 PM
glenbear
Apr 13, 2011 08:01 PM
ID VTWIN
Dec 23, 2009 04:21 PM
Big Pig
Dec 12, 2009 04:52 PM
My Fix
Oct 11, 2009 02:44 PM
