Hidden Antenna
Old Oct 30, 2011 | 08:54 PM
LoBoy's Avatar
LoBoy
Default Hidden Antenna
As part of my winter project list, a hidden antenna is on the list.
Can anyone recommend a high quality antenna? Everybody that I have talked to says they have had zero luck with anything other than the stock type.
Old Oct 30, 2011 | 09:09 PM
Paulster66's Avatar
Paulster66
I went with the HD offering, part 76000040.
I did notice a slight lose in reception but works well for me in FL. Don't have much of a terrain issue to deal with. I also picked up the plug to install when I removed the factory antenna.
For me cleaning up the rear end was more important.
Old Oct 30, 2011 | 09:37 PM
2black1s's Avatar
2black1s
Check out this thread. I did this to mine and I'm completely satisfied. https://www.hdforums.com/forum/touri...-st-glide.html
Old Oct 30, 2011 | 10:26 PM
Bearcat1's Avatar
Bearcat1
HA-1W
May be the best out there. I have one and love it.
http://www.eglidegoodies.com/id126.html
Old Oct 30, 2011 | 10:40 PM
Grind's Avatar
Grind
I got a Metra brand antenna from Advance Auto Parts for $22, mounted in my fairing. It actually works better than the stock whip.
Old Oct 30, 2011 | 10:49 PM
KACook's Avatar
KACook
Don't waste your money. I have a Dakota Digital. It does not work. / I am using the factory antenna right now.
I saw another thread on here that the op turnde the existing antenna mount and laid the antenna across the saddlebag bracket and under the seats edge, using tie raps. When everythings together, you can't see it. This is what I plan top do.
Save the cash,
Ken
14longshot's Avatar
14longshot
I got a hidden antenna with am fm and wb off ebay for less than $20 that works fine not as good of reception as original but not bad. I've been using pandora off me phone so don't listen to the radio as much.
Old Oct 30, 2011 | 10:52 PM
FSCparrothead's Avatar
FSCparrothead
I used the one from HD and I still have nice reception in Wyoming.
Old Oct 30, 2011 | 10:54 PM
Cowboy Rob's Avatar
Cowboy Rob
Big Kahuna HDF Member
Originally Posted by KACook
Don't waste your money. I have a dakota Digital. It does not work.
I did what the above thread shows. It works.
Save the cash,
Ken
I pretty much agree. I had one and it worked ok,but not worth the money. If looking at a scale of 1-10,the stock whip a 10,I would give the DD a 4.
DeneFXDWG
Audio Systems
Sep 3, 2015 07:20 AM
Mcarso1
2014-2024 Touring Models
16
Sep 18, 2014 07:44 AM
SecondGear
33
Aug 13, 2014 06:59 PM
rkoener
Audio Systems
Jun 16, 2014 07:26 AM
00wildcat
Dec 22, 2011 12:52 AM
