So my left hard bag on my 97 roadking shacks like a motha f'er ...can't get it to adjust right...tried the rail ...tried the mounts....it wont stop any suggestions
When you removed the seat you had to remove the seat strap bracket. It is possible it was not put on correctly.
#1 Pull the bag off and check underneath to make sure the rubbers are still on.
#2 Loosen the strap bracket but don't remove.
#3 Put bag back on making sure it falls on the bottom rail in propper place.
#4 Put the pins back on locking postion
#5 Tighten the bracket holding the strap and pin.
