Anti-seize
Old Nov 3, 2011 | 10:03 PM
  #41
Nute's Avatar
Nute
I've been using the Locktite products for years on both large and small diesel and gas engines onboard ships operating in very harsh environments. Locktite has a handy kit that contains five sticks of the most common thread treatments for locking and lubricating threads. It is quite handy to have in the garage when working on your bike or automobile. (Loctite 38725 Loctite Thread Treatment Sticks Kit - 5 sticks) Just remember if you use the red highstrength thread lock you will have to use heat if you ever need to remove the nut or bolt in the future.
The silver "anti-seeze" can have either a nickel or zinc base. The nickel is recommended to be used with stainless steel and the zinc recommended for use with aluminum such as your engine and cylinder heads. The zinc base can also be used with stainless steel. If asked I would recommend the zinc based thread lubricant when working on your bike.
The Copper base antiseeze is for high temperatures (upto 1800 Degrees F and can be used with stainless steel and high nickel alloy bolting.
Old Nov 4, 2011 | 07:53 AM
  #42
soft 02's Avatar
soft 02
Here ya go. No more messy brush or long drawn out threads.
http://www.all-spec.com/products/41205.html
MikeSz
Oct 25, 2018 05:11 PM
bobalew
General Topics/Tech Tips
Mar 18, 2013 05:20 PM
JONNIEROCK
Oct 20, 2009 02:14 PM
spankustang
Exhaust System Topics
May 19, 2008 04:38 PM
campdreamer47
Apr 9, 2006 01:28 PM
