Upgrading mufflers, should 2005 FLHT computer be flashed or not?
Old Nov 9, 2011 | 09:26 PM
DesireBagger's Avatar
DesireBagger
Default Upgrading mufflers, should 2005 FLHT computer be flashed or not?
Have a 2005 FLHT and I'm installing Rush slip on mufflers with 2" baffles and will change my stock air cleaner to a K&N. Will the computer need to be flashed or not? Is there anything els I need to do to the motor after these changes?
Old Nov 10, 2011 | 04:51 AM
electradad's Avatar
electradad
If that is all you are going to do, you would be okay with a "stage one" download from the dealer. If you are thinking about doing anything else (cams, larger bore..etc) then you might want to consider a tuner of some type. You will find that there are several worthwhile options in that line.
Maybe some of the guys that have had the download done can give you an idea as to what it cost. I think its around a hundred bucks, but dont quote me on that.
jbmss
Jun 14, 2011 06:36 AM
jbmss
May 8, 2010 04:19 PM
robcorp421
Mar 31, 2008 01:02 PM
Mac
Oct 19, 2006 03:22 PM
rmwill
Jul 19, 2006 03:41 AM
