RGU Dyno Numbers not what I expected
Old Nov 10, 2011 | 08:15 PM
aviscomi's Avatar
aviscomi
Originally Posted by mtclassic
those numbers are in line with what a stage 1 103 makes. this is one that I vtuned and just did a dyno run to see where it was at. I agree stock cams are not going to ever get much higher then mid to high 70's.
This Dyno is from a stock 103 (i.e. no Stage 1)?
Old Nov 10, 2011 | 09:01 PM
Kingspoke's Avatar
Kingspoke
Cams will really wake up a 103, w/o head work.
Old Nov 10, 2011 | 09:12 PM
mtclassic's Avatar
mtclassic
no this a stage 1 ie supertrapp and se air cleaner and tts vtune.
Old Nov 10, 2011 | 09:19 PM
FDHOG's Avatar
FDHOG
My Stage 1 103 gets 78hp and 93tq. V&H Power Duals and Monster Rounds. What do you consider HOT? In city traffic I see oil temps of 250-260 on hot days. On the Hwy I run 220-225
Old Nov 10, 2011 | 09:25 PM
Ozoneman's Avatar
Ozoneman
Just to give you more input, here are my numbers.
81 hp, 99 torq
Old Nov 10, 2011 | 09:41 PM
fettnersa's Avatar
fettnersa
Hot was a 70 mile highway ride home from dealer feeling a lot of engine heat coming up and oil temp was 253 when I parked.
Old Nov 10, 2011 | 10:01 PM
cptdenny's Avatar
cptdenny
A 110" Stage lll with $4K in engine and pipes mods gets one 110 HP 120 TQ.
Polished & Ported Heads, T-Man 625 Cams, Full Sac 2" with X-Pipe, SE Tuner, Titanium Valves, Heavy Duty Pistons, Adjustable Push Rods, Bored Cylinders, Dyno Tuned, 13.5 to 1 Compression.
Old Nov 10, 2011 | 11:04 PM
pargenz's Avatar
pargenz
Another data point, my 103" stage 1 does 83 hp and 100 tq.
Power Duals, Monster Ovals, PM Super Gas a/c.
Old Nov 10, 2011 | 11:36 PM
user 8373900's Avatar
user 8373900
Don't get too hung up on the numbers, if you like the way it rides enjoy it.
Or have them do a 5th gear pull, you'll get your big number.
Mark
Old Nov 11, 2011 | 05:36 AM
mtclassic's Avatar
mtclassic
well on an air cooled motor with all kinds of wind protection ie the fairing and lowers you are going to feel heat off the motor. oil temp sounds about right. If you are in Florida I am guessing the ambiant temps were fairly warm. pull your lowers off and you feel much cooler. also it really is hard to compare different dynos. all going to read a little different. One operator might weigh 300 lbs and sit on the bike the next might stand beside the bike when he does the run and lots of other things make the numbers all different. so far it looks like most of the stage 1 103's are all in the same ball park.
