No, read your post. You blamed it on a loose connection as well as talking about blowing fuses. Not trying to **** in your punch bowl, just trying to help another out.
If the connection is loose you raise the resistace which pulls more amps....Just a little electrical lesson.
Raised resistance = increased heat at the point the resistance is raised, which in this instance was a loose connection resulting in a melted plug. I was also trying to help another by pointing out the simple problems most people will overlook because it has to be a MAJOR problem since its on a Harley.
Any H4 bulb will work, including the 80/100W high-output type.
iclick where is your post on this? The one with the E-code housing and lamp. I did it and man I tell you what for that little bit of dollars what you get is just amazing thanks again for that one dude.
Thats correct, and if that was actually what you said I wouldn't have commented.
