dobeck tuner with 255 cams?
Old Nov 20, 2011 | 04:59 PM
shagnasty's Avatar
shagnasty
Default dobeck tuner with 255 cams?
What Im looking at is a stock 103 with catless headpipe, HD ventilator a/c and Rinehart 3.5 slip ons. If I add the 255 cams can I run the Dobeck tuner?
Old Nov 20, 2011 | 08:44 PM
shagnasty's Avatar
shagnasty
anybody?
Old Nov 20, 2011 | 08:47 PM
1931jamesw's Avatar
1931jamesw
Never heard of a Dobeck. I would stay with a TTS, SE Pro Tuner or Power Commander whichever your local dyno operator likes and is most comfortable with. If he doesn't care which of those 3, read up on them and go with the one you like best.
Old Nov 20, 2011 | 11:08 PM
Lonewolf176's Avatar
Lonewolf176
Dobeck is aka Mark Dobeck, the founder of Dynojet. It will only control the fuel side. Adding the 255's you will need access to the timing. Using any of the flash based tuners mentioned by 1931jamesw is much better. I am biased to the TTS because it gives you access to more areas to tune your bike.
Old Nov 21, 2011 | 01:10 AM
Gearhead3's Avatar
Gearhead3
With the Dobeck, you really don't know where your A/F ratio is. (unless you have access to a wideband 02 sensor with readout) Also, as stated above, you'll need some way to adjust the timing. The 255's are going to build more cylinder pressure and pinging may become an issue. I had a Dobeck on my Night Train, set to their recommendations, and had severe pinging issues. Never could get rid of it. I went with a PC V on my RG and couldn't be happier. It runs flawlessly.
jkloeker
28
Feb 5, 2016 03:39 PM
Blvfisc
Dec 14, 2015 11:18 AM
jdw1
Jan 7, 2015 11:43 AM
WideGlideFever
Oct 1, 2012 06:19 AM
62pan
Jul 26, 2011 06:11 PM
