Voltage Regulator issue or something else?
Old Nov 24, 2011 | 08:46 AM
grbrown's Avatar
grbrown
Do the checks I mentioned above and let us know what you find.
Old Nov 24, 2011 | 10:37 AM
fabrik8r's Avatar
fabrik8r
Originally Posted by Ikeman1970
Hi! I have a 2001 Ultra Classic w/Fuel Injection. I was riding and the check engine light came on, I got stopped and the bike wouldn't start - nothing - no lights, gauges, etc. Put the charger on it for awhile and then the lights were back, and the bike started. Couldn't find anything wrong. Took it out for a test ride, got about 10 minutes in and the check engine light was back on and the bike started running rough. When I stopped, the bike was dead again. Put a meter across the battery and get about 12.4 V. The three things that I think it could be are battery, voltage regulator, or stator. Anyone know of a likely candidate?
Thanks.
Rick
Sounds to me like you are right, it could be the battery, regulator, or stator, or any number of other electrical gremlins, but applying the electrical troubleshooting procedures in the service manual should tell you exactly what is wrong. It's really hard to evaluate electrical issues over the internet, your results from charging the battery basically narrows it down to the three main possibilities you already mentioned. The battery is easiest to check, I would start there.
Old Nov 24, 2011 | 10:58 AM
SIDECAR BOB's Avatar
SIDECAR BOB
Thanks.
Rick
check connections on the battery terminals, or the main circuit breaker, if that doesn't work take the battery and have load tessted , it could show ok voltage but not have amperage capacity to start the bike
Old Nov 25, 2011 | 01:05 PM
jchill's Avatar
jchill
Thanks all for the tips. Should have warm enough weather to get in the garage and step through everything you all mentioned. I'll repost as soon as I get through it all.
@sidcaebob..not sure just what part fo 'central illinois' but thats where I originally hail from. born and raised.Springfield.
Old Nov 26, 2011 | 05:23 PM
Ikeman1970's Avatar
Ikeman1970
Stage IV
Default Voltage Regulator Problem Solved
Thanks for all of you good ideas . . . everything looked good till I got to the battery. Across the terminals I was showing almost 13 Volts, but on the pigtail for the Battery Tender I had dropped to 9 volts. When I saw this difference, I checked my connections more closely, sure enough the negative was loose. Passed the initial test, so I think we might be good.
Thanks everyone!
Someday hopefully I;ll get to meet you all.
Rick
glw165
Electrical/Lighting/Alarm
Mar 8, 2015 05:37 PM
c50plus
Sep 30, 2014 12:33 AM
im
Jul 27, 2012 12:52 PM
odie-in-az
Apr 8, 2010 11:44 AM
dan789
Jan 2, 2006 12:04 AM
