View Poll Results: Did you put a gear drive in or keep the stock chain and tensioer
I stayed with the stock chain and tensioner
96.15%
I replaced the stock set up with a gear drive
3.85%
Voters: 26. You may not vote on this poll
Touring camshaft question
Old Nov 23, 2011 | 10:39 PM
Azdeluxe's Avatar
Azdeluxe
Default Touring camshaft question
I understand since 2007 cam tensioner has changed and according to
several HD-Dealers that they really dont put in gear drives much at all in the late models since tensioner change while an independent shop told me to definatley put a gear drive in as the tensioner is still problematic. How many of ya'll put in gear drives while doing a cam upgrade and how many left the chain in.
Old Nov 23, 2011 | 11:15 PM
aktid35's Avatar
aktid35
i had 8K on my tensioners and they had almost no wear did the swap just today. from the looks they would be good for 40k easilly
Old Nov 24, 2011 | 02:10 AM
thenewrage's Avatar
thenewrage
Bolt in cams. 07 sg
Old Nov 24, 2011 | 08:11 AM
Tripleshot's Avatar
Tripleshot
Did it myself in my garage with no problems. Needed to tune right after. That was biggest challenge. I love my cam. Best upgrade I could have done.
Old Nov 26, 2011 | 12:51 PM
Azdeluxe's Avatar
Azdeluxe
I think I'll roll with my Andrews 54's OEM chain drive. Im sure they'll last a long time.I just checked the poll...and WOW, very interesting results..So far 100% stayed with the stock set up.
Old Nov 26, 2011 | 12:57 PM
MNPGRider's Avatar
MNPGRider
With the increased crank runout specs, I would think most would no longer use gear drives.
Old Nov 26, 2011 | 01:00 PM
1931jamesw's Avatar
1931jamesw
The problem is the run out on the late models is usually to excessive for gear drives. Sounds like your guy is not up to date on things or is just kinda stuck on his way of doing things. The new hydraulic tensioners are much more forgiving on crank run out and considerably cheaper too. I wouldn't even consider gear drives anymore myself but thats just me being stuck on what I believe is best too I guess.
BLACKTOP GLIDER
Apr 3, 2010 06:03 PM
ydnob
Jun 29, 2009 09:27 PM
white trash
Aug 15, 2008 05:17 PM
pauletich
Apr 12, 2008 04:41 PM
Boomshaw
Exhaust System Topics
Aug 22, 2007 10:54 AM
