Hidden add-ons
the "hard" tour pak mount or the detachable- your choice
pick the big or small backrest pad
so basically you decide what you want and get it.
or watch the classifieds and get something and make it fit ( 09+ mounting hardware will not work on your frame)
I don't use gps or helmets or comms... so even less help there
Mike
As to a mount you can use just about anything RAM puts out, from a handlebar clamp, or a ball mount bracket that bolts in place of part of your clutch bracket or the one I use, the mirror mount hole ball mount.
http://www.ram-mount.com/CatalogResu...5/Default.aspx
My brother has the Garmin 665 (hope thats the right number) and he uses it with his helmet to listen to the XM radio and hear the GPS directions.
BUT, consider that person who has all of the parts and pieces but just wants to repair a single item or two and if not sold in this manner will have to purchase a bunch of unneeded parts just to repair a single item....
Now that would really !@#@!&*!!
As to comm units- they can be moved from helmet to helmet; and there are a number available. I have used and like J&M personally for some of their items; and service.
And FWIW, no chuckling here....
Your best bet to find a Tour Pak that has the speakers and other accessories already attached is to watch the classified, or eBay.
To add the rear speakers, switches in the speakers and the intercom system requires you to decide how you want to proceed.
You can purchase two different "Intercom/Music kits, depending how you want to wire the rear speakers and mount the Tour Pak. No mater how you go, one part that both kits require is the Non-Ultra Wiring Harness (70169-06). Both kits plug into this harness.
The least expensive and easiest one is to solid mount the Tour Pak and add the Boom!™ Audio Music and Intercom Kit for Tour-Pak® Models (76440-06). This includes the Rear Speaker w/switch wiring, and Passenger intercom. You will still be required to purchase the Boom!™ Audio Communications Switch Kit () to plug in the Rider Headset. It mounts in the Fuel tank dash. This kit also includes the left handlebar control that is already on your bike. What I did was to watch eBay for the dash to come up. I saves a lot of money.
To use the Detachable Kit, you will need to use Boom!™ Audio Music and Intercom Kit (77107-09). This kit includes the Rider as well as the Passenger headset hook ups. It also includes the Speaker switch and left handlebar control, that you again already have on your bike. The only problem with this kit is that it eliminates the wiring to the rear speakers. You can still add the rear speaker harness (77157-06) but will need to wire it your self. (That is what I did with my '09 Road Glide). This way I can have the intercom/Music for my Headsets with or without the Tour Pak. And I can still have the rear speakers when I attach my Tour Pak.
The Detachable kit for your '08 is as follows.
Touring Detachable Rack . . . . . . . . . Docking Kit
Two-Up Tour-Pak Rack P/N 53276-04 53804-06
If you have any questions, let me know and I will try to answer them.
then you just need a little rack or backrest
mike
