Changing brake pads
Old Nov 26, 2011 | 12:44 PM
Astro's Avatar
Astro
Default Changing brake pads
I need help.
What size sockets are the spline looking bolt heads? I tried a torx socket and the wall thickness on the socket is too wide to fit the pad pins so I can't tell if the size is right or not.
Thanks for the help!
Old Nov 26, 2011 | 12:50 PM
gobblerhuntr's Avatar
gobblerhuntr
I think it is a 12 point head so you will need a 12 point socket for best results. I can't remember the size, is it 1/4"?
Old Nov 26, 2011 | 01:02 PM
SportyPig's Avatar
SportyPig
It is a 12 point head, and it's millimeter. I haven't done this on my UC, but the Sporty is 10 mm 12 point
And I know from working on friends Dyna's and Softails, they are also 10 mm 12 point. I just haven't done a brake job on a Touring bike yet.
Old Nov 26, 2011 | 01:05 PM
PistonPuller's Avatar
PistonPuller
12 point 10mm
Old Nov 26, 2011 | 01:22 PM
thenewrage's Avatar
thenewrage
Front caliper bolts, you need a 12pt 10mm socket. Little bolts to remove pads , you need a 12pt 1/4 socket
Old Nov 26, 2011 | 01:31 PM
PistonPuller
Unless he has a bike with Brembo's. Then it is a allen head. Cant remember the size though
Old Nov 26, 2011 | 03:16 PM
lkr0's Avatar
lkr0
correct, just got one at home depot--took me about an hour to do the brakesQUOTE=PistonPuller;9080953]12 point 10mm[/QUOTE]
roussfam
Oct 7, 2017 12:42 PM
fatbobsd
Aug 7, 2015 08:36 PM
Jersey Drew
Mar 16, 2015 06:34 AM
CSS_FXD
Apr 20, 2012 04:27 PM
deerjackie
Aug 8, 2008 01:40 AM
