no spring compensator
Old Nov 20, 2013 | 12:26 PM
Timusa's Avatar
Timusa
Default ...continued – more pics
Here are the pics from final assembly and from the second assembly – after stator replaced.
Attached Thumbnails no spring compensator-p7141885.jpg   no spring compensator-p7141886.jpg   no spring compensator-p7151887.jpg   no spring compensator-img_4350.jpg   no spring compensator-img_4354.jpg
Old Nov 20, 2013 | 12:30 PM
Timusa's Avatar
Timusa
Originally Posted by bigdumbnoitall00
the bang at start up will eat your starter,it's all the low rpm torque pulses that will tweak the crank,the comp is working all the time to soften the pulses.
Just to stress it once more – this is COMPENSATING sprocket, not anything else, and it functions exactly like SE comp but being smaller and lighter.
Old Nov 20, 2013 | 04:55 PM
customsoftail200's Avatar
customsoftail200
I've had mine on for over 8000 miles and it's all good. No more noise at start up, pretty smooth running and taking off. I'd do it again on another bike if I had to.
Old Nov 20, 2013 | 07:26 PM
Tee Bagger's Avatar
Tee Bagger
I have the solid sprocket... no comp. I have about 10k miles on it, with no issues. Its so much smoother taking off and shifting... very noticeable! Its my opinion that this should last a long long time as long as your not beating the hell out of it. If that's how you ride, you may want to weld the crank.
Old Nov 26, 2013 | 01:27 PM
VETERAN75's Avatar
VETERAN75
What do you have? Solid sprocket? No comp? I'm doing a 110 and I'm looking for a fix to the comp problem I've considered a solid engine sprocket but I'm concerned if there are any negative consequences I would have to live with. Vibrations, noises, something else breaking like the starter components.
Old Nov 26, 2013 | 05:49 PM
dbell66253's Avatar
dbell66253
I've been looking at the Vulcanworks solid sproket, I've heard nothing but good things about it so far.
Old Nov 26, 2013 | 08:28 PM
customsoftail200
The BDL is a great piece, and doesn't hurt the wallet too bad. I love mine.
Big Money
Mar 16, 2015 03:49 PM
D_gyver
EVO
30
Feb 20, 2015 08:00 PM
deedee4150
Jul 24, 2013 07:13 PM
WRAITH
May 30, 2010 11:18 PM
52wrench
Oct 11, 2007 05:39 PM
