Cam chest blues
The chunk of tooth found it's way to the pump also..
There's a couple of bearing issues, depending on your engine manufacture date; and some other cam chest concerns for 1999.
1. The bolt used to attach the drive sprocket to the rear cam could loosen and cause the rotational force to shear the cast key of the sprocket, causing engine failure. The design was changed to the splined setup that's used now, as well as a bigger bolt. Mine never had an issue, but the condition does exist.
2. The bearing used in the cam support plate for both the front and the rear camshaft was originally a ball bearing. The rear bearing failed due to the extra loading and the design was changed to use a roller bearing for the rear only.
3. The inner cam bearing is an INA manufactured one, with rollers spaced apart by a steel stamped "cage". Many here (myself included) prefer the Torrington bearing that has more rollers without the steel spacing cage.
4. The cam chain tensioners are a wear item, and seem to wear inconsistently. I pulled mine at 38k, and they were worn, but still OK, others have had them disintegrate much earlier, and cause lots of engine damage by being ingested into the
A: oil pump and scarring the cam support plate with a resultant loss of oil pressure
B: cam bearings
C: crank bearings
These are the worst case scenarios, and many have had their bikes run long and trouble free.
I weighed the options, and decided a gear drive and all new bearings was the best route for me. You have to pull everything out anyway just to change the rear cam support plate bearing, and to me it made sense to get the biggest bang for the buck by doing all the cam chest work at one time.
They are cheaper than buying stock cams, and btw I could not see what the lobes where like in your pictures(phone cam pics?)
Re-use the original chain as was mentioned . It will be nicely polished from the first or second set of tensioners (installed by first owner?) and likely will be fine.
Replace the cam bearings with bearings of choice as long as they are not the inna bearings..there is one less bearing in the cage if I recall , then again it has been three years since I went with the SE retro fit cam plate and oil pump.
The other thing to look at is the cam lobes and the lifter bearings for wear ..it would be a shame to do this work now and then have a failure come spring riding season.
Take my info for what it is, just an opinion.
Rob
The reason I took it apart.
The new tensioner installed on the inboard side of the cam support plate.
