ok so i improved my living conditions but the bike suffers, now. always had my bike in a garage or shed of some type. now it sits outside in the elements 24/7. I just noticed yesterday that the "waterproof" cover i have on it in trapping water between it and the leather tour pak i just put on it, causing mold! and spots where the leater looks like its chickenpox. i was hoping i didnt need to spend $400 on a shelter for it this winter but maybe its best. i have friends that can put under a carport but i like to be able to just jump on and ride when i want also i like to see that its still there everyday rather than wonder what happened to it while sitting somewhere out of view. anybody got any ideas?
Do you live on the ground floor if so take off the bags and move it inside. Or rent a house with a garage
check out cycle shell, my buddy has one going on 5 years holding up pretty good for NY winters. a little pricey but can fold up and be brought inside for storage when needed
is a small enclosed trailer out of the question?? it will only take up a parking spot..& it can be used for other things later.. if you have a vehical to tow it...
If you don't have a place to keep a bike dry or out of the weather. you may look around,
Make sure it has a let down door. And you can ride your bike in with the windshield on.
You can run a extension cord and put a light in them for heat to cut down on moisture.
If you live somewhere , make sure you can park one there. And put a lock on the tougue
This is the best thing I know for a Bike.
You will need a wheel choke inside the trailer to ride the bike in.
You can find them used. But make sure they are in good shape.
