Built the best engine cooling system...again
First let me say that you are one of the forum members who's opinions I respect.
I also played with oil cooler fans, and while my fans did not fail from the bike environment, i.e., heat, vibration, etc., they did fail from road debris. When I took them apart I found little gravel like pebbles had found their way into the fan motors and bound them up. When I disassembled the fans and removed the road debris they worked fine again. Protecting the fans with a screen would probably solve the problem I found, but I simply opted to remove them. I may play around with them again at some point but I'm not sure.
Now as for cylinder head (or engine cooling) fans, whether the LeNale, fabrik8r's design, or any other, they are definitely a worthwhile pursuit. I will never remove the engine cooling fan from my bike, and if and when it ever fails, I will replace it immediately. From my experience and testing, there is no better bang-for-the-buck cooling methodology available. While oil coolers, and oil cooler fans do have their place, the engine cooling fans attack the heat at its source and minimizing that heat heat also has a relative effect on oil temperatures. If I were buying a new bike today, an engine cooling fan would be one of my first mods.
I don't have the link but it was from an SRT (Chrysler/Dodge Group) Engineer Chat Session on one of the LX related forums (LX/Charger/300/Challenger) forums.
