ABS light stays on
Old Dec 21, 2011 | 10:51 PM
  #31
MikeB's Avatar
MikeB
I'm trying to clear up any issues with this bike because I'm thinking about selling it or trading it in. Besides, if I do keep it I don't want to have these issues either.
Old Dec 22, 2011 | 09:19 AM
  #32
MikeB's Avatar
MikeB
A possible explanation for the codes and ABS light issue may have been caused by the mechanic who last worked on my bike. I took it in for new tires and while it was there I asked them to change the oil in the motor and primary case. It is possible the mechanic started the motor after changing the oil but while the wheels were still off. This would have set up the condition of the front WSS not properly positioned and setting up the fault code. If the mechanic realized this, he could have cleared the code and saved me a lot of grief.
Old Dec 22, 2011 | 09:34 AM
  #33
Aborigen2's Avatar
Aborigen2
I don't think so. If you were riding and the ABS light was solid ON that means you had a current code, something has happened to the WSS within that ignition cycle. It is possible that the mechanics have triggered an error code, but if the condition no longer existed that code would have become historic and you would not see the ABS light staying solid ON while driving.
Old Dec 22, 2011 | 09:51 AM
  #34
blusmbl's Avatar
blusmbl
Slight brake drag is not going to cause the ABS light to stay on. I've done rolling burnouts in the rain on my bike, if the wheel speed difference of a slightly dragging brake would leave the light on it certainly would come on for burnouts and that is not the case. It's indicating an open circuit, so check the wiring, then check the sensor at the wheel. Pretty simple, hopefully if it's the sensor it's cheap from a dealer.
The light goes out as soon as it sees 3mph from both sensors. If the light is not going out, you're not getting wheel speed from one or both of them.
On our bikes the rotors are definitely the floating pieces. MC's usually have floating rotors, not calipers.
I would think if the rear brake switch has set a code you won't have cruise control. Does the rear brake pedal activate the brake light?
Old Dec 22, 2011 | 10:10 AM
  #35
Aborigen2's Avatar
Aborigen2
I certainly agree with you, no codes are set when the rear wheel is faster than the front wheel- this is a normal condition not just when you do burnouts but when you ride on slippery rode. The other way around, if the front is faster than the rear wheel with no brake applied then the ABS will set a code.
This is why I still believe that the problem in this case was not a drug on the front wheel but rather imporper re-assembly of the WSS after they replaced the wheel. Broken wire is not the suspect- otherwise it would make no difference does Mike back up the bike or goes traight forward. From his description it looks like that the ABS code is set only if he first backs the bike up, then goes forward. Which indicates that there may have been some play between the WSS and the magnetic ring inside the hub.
As for not being able to set the cruise if you had a brake switch code - that would be true if the code was "Brake Switch Shorted" code. Mike had an "open" code (the ABS did not "see" brake switch applied when the vehicle was actually decellerating). Open Brake switch does not prevent setting the cruise, only closed (shorted) brake switch does. Open Brake switch is normal condition while you are riding.
Old Dec 22, 2011 | 11:31 AM
  #36
Aborigen2's Avatar
Aborigen2
Mike’s problem kept me scratching my head and with the help of my neighbor I managed to set a Front Wheel Speed Sensor code while simulating binding front brakes.
Here is what we did:
- Disconnected the Front Brake Switch so that the ABS has no idea if the brake is applied or not.
- Turned Ignition ON and accelerated the bike somewhat downhill till it exceeded 3 mph
- Then applied the front brake while still pushing the bike backwards (to simulate binding front brakes)
The ABS set a code; the ABS Light came solid ON.
Then we started the bike (without cycling Ignition OFF/ON), the ABS light stayed ON.
We rode for 5 minutes, the light stayed on.
Then we stopped the bike, all lights went OFF.
Reconnected brake switch, rode the bike – everything was normal
Now, for a single person to be able to repeat this one has to back up his bike really downhill, to be able to exceed the 3mph threshold.
Wild guess, but is can be done.
Old Dec 22, 2011 | 12:24 PM
  #37
blusmbl's Avatar
blusmbl
What code did it set when the ABS light was on?
If both brake switches have an open circuit code the cruise control has to be disabled otherwise Harley has a lawsuit on their hands. I would not be surprised if cruise is disabled for an open circuit on just one of the two brake switch inputs.
Old Dec 22, 2011 | 01:06 PM
  #38
2black1s's Avatar
2black1s
...The Harley calipers are fixed and the rotors float...
Sometimes the manufaturer floats the caliper and sometimes they float the rotors, either way one of them has to float. On the 08 models with the ABS Brembo brakes, the caliper is mounted solid to the forks and the rotor has soft bushings where they bolt to the wheel...
...On our bikes the rotors are definitely the floating pieces. MC's usually have floating rotors, not calipers...
You guys are right in saying that something has to float in a disc brake system. Something has to have the ability to move to compensate for pad/rotor wear and manufacturing tolerances. But it doesn't always have to be the caliper or the rotor. Where the necessary "float" is actually present in the HD/Brembo system is not the caliper or the rotor, as each is fixed, but the brake pads within the caliper. Each pad has its own piston(s) and those pistons/pads can float side to side. This is how the necessary float is incorporated into our bikes.
Aborigen2 - Welcome aboard! It's nice to have someone with your knowledge of electronics on board. Electronics is one of my weaknesses.
Old Dec 22, 2011 | 01:09 PM
  #39
Aborigen2's Avatar
Aborigen2
J)
My bike is a newer Softail, it set C1032 – Front WSS Open code.
Now, regarding the Brake Switches and the Cruise I think you are just a little bit wrong.
Here are my arguments:
1.) On all vehicles I know of the Brake Switches have two legitimate states – Open (no brake applied) and Closed (when Brake is applied)
2.) On earlier vehicles those switches were not diagnosed at all – you had to physically see that the Brake Light does not operate when brake is applied to figure out that the switch has failed.
3.) On many modern vehicles the switches are diagnosed by the ECM and ABS Modules in indirect way:
a. Failed Open – if the vehicle is rapidly decelerating and the modules “see” no brake switch becoming closed
b. Failed Closed – if the vehicle is running at monotonous speed or accelerating while the switch appears as “closed” .Or Brake Switch looks Closed while the gas pedal is applied for longer than several seconds (throttle roll on for bikes).
4.) Brake switches are mechanical devices, they fail all the time. This is why they are not relied upon for any safety-critical function besides turning the Brake Light ON.
5.) To set the Cruise ON both Brake Switches have to be Open anyways. If any one appears “Closed” you can’t set the cruise.
6.) All Cruise Control systems have multiple redundant ways of switching the Cruise OFF; none of the known to me systems relies on the Brake Switches alone.
7.) Harley will bail out of cruise on any of the following circumstances:
a. Brake Switch Closed
b. Twist Grip Roll Off
c. Clutch Pulled IN
d. Vehicle braking (deceleration more than xx miles/ sec, regardless that brake switch may not close)
e. Sudden RPM change
f. Sudden vehicle speed change
g. Gear shifting
h. Internal error of the ECM
i. Any error in bunch of sensors/activators controlled by the ECM (ICM, TPS, TGS, e.t.c)
j. Error in the communication bus
k. Inability to maintain the set speed
l. Lastly and most drastically, vehicle will bail out of cruise if Run switch is briefly turned to “Stop” or Ign Switch is cycled OFF/ON
As you can see there is lots of redundancy in the Cruise Control. You may want to try suing Harley for failed brake switch if you like, but I can’t see you getting more than a buck for it. J)
Old Dec 22, 2011 | 01:28 PM
  #40
blusmbl's Avatar
blusmbl
On production cars if you lose the brake pedal input you lose cruise control, it's more critical for an automatic transmission vs. manual but the principles are the same. I would suggest trying to disconnect both switches, then going for a ride to see if cruise control still works. If it does still work and doesn't deactivate until the clutch is pulled in or the throttle is rolled forward, then it really is a lawsuit waiting to happen and violates many safe practices in terms of vehicle operation and consumer safety. Lawyers would be lining up around the block to take a case where you hit somebody because the cruise control was active and the brake switch didn't cancel it. If you've only lightly used the brakes and it has no idea the brakes were tapped it's going to keep adding throttle to maintain vehicle speed....
BTW, I think you covered it here, but just didn't realize it:
I'll bet a beer the brake switches are under that category.
