Mirror Template.......
Old Jan 22, 2012 | 04:59 PM
07UltraGlide's Avatar
07UltraGlide
sgdiesel,I did move them up a half an inch.I redrilled the holes after the orig install.The big washers on the mirrors cover my boo boo's.I used Black Rtv on the inside under the washer and then installed washer and nut.They r much better 1/2 inch higher.
Old Jan 22, 2012 | 05:03 PM
sgdiesel's Avatar
sgdiesel
Kinda got used to them now but I think I will do as you propose here, I am sure it is worth it
Old Apr 11, 2012 | 11:02 AM
HDV-GLIDE's Avatar
HDV-GLIDE
Originally Posted by dawg
See attached. If you enlarge it to normal size, it will be your template.
Problem is, what's the normal size?? Maybe a measurement from end to end would help. I'm pulling my hair out!!!!
Old Apr 11, 2012 | 01:32 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Jobs done, I found a template online that downloaded at 100%.
I also moved the holes up about 1/2".
Now to put everything back together without Mr. Murphy screwing something up......
Old Apr 11, 2012 | 01:47 PM
sgdiesel's Avatar
sgdiesel
Good luck
Old Apr 24, 2012 | 10:29 AM
Ministro's Avatar
Ministro
Default Template
Could you post the link to the template?
Thanks
ELVISTO
22
Dec 14, 2015 01:18 PM
Nitrochicken
Touring Parts
Aug 5, 2014 09:42 PM
cmc seabee
Oct 26, 2013 08:26 PM
DrewCfromSC
Mar 7, 2011 07:53 PM
Street Star Designs
Touring Parts
Nov 17, 2009 11:21 AM
