Hi guys I have a 97 roadking that has rear break noise......I changed from mag wheel to spoke wheel and this is when the noise started......
Now the mag wheel had a wide pattern rear rotor...so I was not able to reuse that rotor on the spoke rim
the spoke had a tight pattern rotor and used a thinner rotor then the mag wheel...
I've done brakes before and didn't have any problems....
is the rotor the reason for the squealing or could it be something else I haven't thought off....adjustments or something...
Thank u
