Brake lever replacement
Old Dec 30, 2011 | 08:04 PM
elauee1's Avatar
elauee1
Default Brake lever replacement
On a 2010 roadglide to change the front brake lever do I have to remove the handlebar clamp or can I leave in place put a cardboard shim remove the pin and remove the lever. Thanks to all for replys
Old Dec 30, 2011 | 08:06 PM
thenewrage's Avatar
thenewrage
on my 07, it was simple. I didn't touch the handlebar clamp. I didnt use a shim either. 07flhx
Old Dec 30, 2011 | 08:10 PM
KCFLHRC's Avatar
KCFLHRC
You will have to at least loosen the clam shell bolts to get the lever out. Be careful and don't brake off the tip of the brake light switch or you will be replacing that too.
Old Dec 30, 2011 | 08:13 PM
elauee1's Avatar
elauee1
Thanks I replaced the levers on an o6 night train but this looks a little diffrent
vtHDrider
2014-2024 Touring Models
Jul 9, 2017 05:48 PM
rhuff
Mar 18, 2016 02:11 PM
Horses 4 me
Jun 28, 2013 08:23 PM
NOLAMike
Jan 22, 2009 08:06 PM
fxstcguy98
Jan 17, 2006 11:18 AM
