cams
Old Jan 5, 2012 | 06:35 PM
  #91
jeepster09's Avatar
jeepster09
I went with Kuryakyn cams and loved the power.My bike was mostly used solo and occaisional rider. I also went with gear drive.
http://www.kuryakyn.com/Products/1601/Cams-for-Twin-Cam
Old Jan 5, 2012 | 07:15 PM
  #92
Twinrider's Avatar
Twinrider
Originally Posted by boogaloodude
There's always more a guy can do. I'm in the middle of a 107/tw8 build with ported heads, and I've already completed the 30t trans pulley to go along with the 68t whel pulley I installed last summer. I'm hoping that's going to hold me over for awhile
Changing the pulleys lowers the gearing? How is it at highway speeds?
I know I can always go bigger than the 103, just wondering how to squeeze more power out of my 103 without making the bike louder or breaking the bank...
Old Jan 5, 2012 | 09:39 PM
  #93
Tn.Heritage's Avatar
Tn.Heritage
I have never seen any one praise the 255's as most of you have in any thread. They are good cams but the 204's will pull and run better than the 255's any day. There, I said it. Just wish I could write about the 204's for 10 pages.
I'm just kidding. To each his own. I'll have to say though the SE cams are a great bolt in cam set. 203, 204, 255, 254e's. And then you want have another guy say then to really make that cam work for you advance the cam's 4 degrees and pull the heads and get the compression to 10.1 and she'll fly. No what I mean...
Old Jan 5, 2012 | 10:02 PM
  #94
SunCruise's Avatar
SunCruise
They certainly are popular. I'm considering the Woods 555 but not sold yet. Now I would really like to know more about the SE 204. From what I have read they seem to be a great choice. Are 1.725 rockers needed or an option? One characteristic that caught me in a thread on these was "drivability" Would love to hear from any who run them.
SC
96--> 103" TTS (cam) V&H DDuals, MRounds
Old Jan 5, 2012 | 10:46 PM
  #95
ocezam's Avatar
ocezam
Originally Posted by Allen Dye
I guess we ride completly different and you won't be able to answer my question about the other cam. I don't ride at 2000 rpm all the time, I do spend a lot of time at 2300 to 2400 rpm on roads like the BRP. The BRP has a 45 mph speed limit and you can go 50 to 52 wiith out the park rangers stopping you. Crusing at fifty put the bike right at 2300 rpm in fifth, hit a steep uphill curve and you will be forced to drop to 45 and that puts the bike right at 2000 rpm. That forced a downshift to forth with the stock cams, if I was a little slow getting around to downshifting or the curve was fairly steep, I would have to downshift to third. Since installing the 255, if I drop to 45 on a steep uphill curve, I just roll it on on exiting the curve and go right back to 50 to 52 mph and 2300-2400 rpm, with out have to downshift. The bike doesn't lug or buck, it just smoothly accerates. That's the way I ride, if the crank won't hold up to it I'll either repair it when it goes out or trade it in on a new Wing that will stand it, day in and day out for hundreds of thousands of mile. I have no interest in a cam that waits until after 2500 rpm start making good power, but I would be interisted in one that made the same power down low like a 255 and still had a flat curve past 4500.
Yes, we definitely ride differently. Guess that's why there are many different grinds. I'm glad your happy with your cams.
Old Jan 5, 2012 | 10:52 PM
  #96
ocezam's Avatar
ocezam
Here's the best thread I've found on ratio changes:
https://www.hdforums.com/forum/touri...7-and-08s.html
Also, I'm not sure what pipes you have, but Supertrap Fatshots are a great performance pipe while remaining relatively quiet. You can tune the sound and performance.
Old Jan 5, 2012 | 11:08 PM
  #97
sanaga's Avatar
sanaga
i just installed s&s 583 easy start cams on my 11 limited
strong at 3000-4000 range....match my riding style....the bike now pulls like no others day.....it keep pulling and pulling ....on a straight road, i hit the 120 mph mark on my speedo....which impossible to do when still on my stock cam....
Old Jan 5, 2012 | 11:09 PM
  #98
Mike's Avatar
Mike
Originally Posted by atrain68
I did the 68t pulley as well. But a 30t trans pulley and a tw8? Will your front wheel touch the ground?
Guess I had a little project creep....
Old Jan 6, 2012 | 07:53 AM
  #99
Allen Dye's Avatar
Allen Dye
What you are describing is a gearing issue, not a cam selection issue.
No, it's not a gearing issue, it's an issue of the bike not pulling worth a hoot stock, the gearings just fine. If it was geared lower by changing one of the pulleys, than it would be geared to turn too fast when on the interstate.
When I was in my early twenties, I rode a 350 Yamaha. We rode the BRP a lot with friends and as long as nothing got in the way that bike would run the intire parkway, two up, in fifth gear. Other modern bikes with similar gearing as my Limited will run the Parkway without constantly have to be shifted like a 125cc bike, I expect the same out of a 1690cc Harley. With the 255s and stock gearing it runs like it should, with a relaxed none screaming ride on the interstate and the ability to pull good in the mountians in forth and fifth gears, without constantly having to be shifted. This is a touring bike and is used by some of us to tour. Seems like some only worry about how much faster and quicker they can make it. If that was all I was worried about, I wouldn't be riding touring bikes to start with.
Old Jan 6, 2012 | 08:38 AM
  #100
05FLHTC's Avatar
05FLHTC
Cool talk about a dead horse...
My cam is better then your cam and why because I picked it!
