cams
Old Jan 4, 2012 | 08:17 AM
  #61
blusmbl's Avatar
blusmbl
Separate from the 255's vs. the world discussion, what's the maximum safe valve lift at TDC for the stock pistons? I see a couple cams listed as bolt in with values of .208" - .214", is that the limit?
Old Jan 4, 2012 | 08:25 AM
  #62
mrfikser's Avatar
mrfikser
I started with a factory 103 stage one bike (flhrc) and wanted to go to stage 2 (add cams) this is how I decided what I wanted in a cam..
1. if possible I wanted to keep the stock push rods ( personal choice) (10%)
2. I wanted to improve low to med rpm power (this is where I drive , and what the motor was designed for) (40%)
3. wanted it to be quite (10%)
4. wanted to maintain reasonable mpg (20%)
5. wanted a cam that would not grossly affect longevity of the motor (15%)
6. wanted it to be a good price (5%)
after researching a bunch of cams I came to the conclusion that the se255 was the best cam for me...there are several cams with similar power profiles and the se255 fit in with them and was cheaper. In my case the price was the item that pushed me to the se255 as the rest of items on the list were available from several cams....for example the woods 555 cam is a good cam with a similar curve as the se255 but it needed to have adjustable push rods installed (smaller base circle) and it can sometimes be noisy also it cost about 25% more than the se255 ( I bought the se255 new off of ebay for $199)
Old Jan 4, 2012 | 12:46 PM
  #63
SunCruise's Avatar
SunCruise
.....Woods 555 needs Adjst. Pushrods ?? Hmmm. I have to look into this now... My Mech. is suggesting 96" build 103-TTS-Woods 555-Comp.Rel.& keep stock PR, says base circle same. I don't want adjustables.
SC
Old Jan 4, 2012 | 01:19 PM
  #64
iclick's Avatar
iclick
Originally Posted by boogaloodude
Post up your dyno chart, Bob, and I'll be glad to continue the discussion.
What dyno chart? Do we really need more charts in this thread that have been posted in others over the past months? Posting more will undoubtedly get more hisses and boos from the audience, you know, and I'm just now cleaning the tomato parts off my face from yesterday. But it's winter and this happens every year.
Old Jan 4, 2012 | 01:23 PM
  #65
iclick's Avatar
iclick
Jamie at Fuel Moto told me that although these are "bolt-in" cams, the base-circles are different and he recommends using adjustable pushrods. I always thought "bolt-in" meant you didn't need further mods for installation, but I guess this isn't the case.
Old Jan 4, 2012 | 02:01 PM
  #66
djl's Avatar
djl
There is no definitive answer to that question. Once again, there are variables at play, i.e., head gasket thickness, deck height and whether or not the heads have been decked. If everything is bone stock and cams "bolt in" TDC lift won't be an issue but total lift may be depending on the model year.
As an example, I have run the SE204, intake TDC lift of .208" with heads that had been decked .065" and a .030" head gasket. The more important issue, for me anyway, what was the piston to valve clearance. In this build, it was .040". I would have preferred to see .060" but had decided I could live with .030".
You won't see TDC lifts much higher than the intake lift of the SE204 when looking at bolt in cams. However, once you start looking at cams with .640" or .720" lift, intake lifts can exceed .250".
If larger intake valves are used with OEM pistons, the position of the intake valve relief can become an issue. The relief is usually deep enough but not positioned properly ant the outer edge of the larger valve can kiss the top of the piston. The valve reliefs need to be flycut and moved out toward the outside of the piston.
Once you get away from bolt in cams and start using thinner head gaskets and decked heads, mocking up the top end and checking piston to valve clearance is worth the time and effort.
Old Jan 4, 2012 | 02:09 PM
  #67
SunCruise's Avatar
SunCruise
Originally Posted by iclick
Jamie at Fuel Moto told me these are bolt-ins, as are the 777, so no adjustables are necessary.
Whew !! thanks. I will discuss with mech. noise issues, perhaps directional lifters. I love it when a plan comes together and I feel it's getting close.
I read were Jamie mentioned Not needing compression releases with the 555's...I don't suppose it would hurt to have them anyway. So far my mech's advice is matching alot of the good advice I find here. 2 up 25% - solo I like to twist it thru the mid-range. All parts working together...hows this pkg. sound ?
S&S AC - 103 - Woods 555 - TTS - Manual CR - Dresser Duals - Monster Rounds
comments welcome
SC
Old Jan 4, 2012 | 02:10 PM
  #68
djl's Avatar
djl
SC
I don't know what the 555 base circle is but just because it is smaller does not mean adjsutable pushrods are necessary. Perfect fits are an option.
Old Jan 4, 2012 | 03:22 PM
  #69
iclick's Avatar
iclick
I haven't actually heard a bike run with the 555's, but I've been told (Jamie, etc.) that they are very quiet, unlike some other Wood cams. The 777's are reportedly quiet, too.
I would think the 103/555 would be a good match-up, and based on charts posted on the FM site I think it would be a winner. All parts working together...hows this pkg. sound ?
I would nix the true-duals, as that will likely affect your low-end performance. I also think the CR's are unnecessary for a 103 with those cams, but other than that I think you'd be happy with this package. I might install one CR, as that might ease stress on the starter, so as long as the jugs are off it might not be a bad idea, as the added cost should be minimal.
Old Jan 4, 2012 | 03:55 PM
  #70
iclick's Avatar
iclick
Everyone please note that I checked with Jamie on the base-circle question, and since it is different than stock on the 555 and 777 he recommends using adjustable pushrods so the lifter engagement can be set accurately. I just changed my earlier post so this is made as clear as possible.
