Help!! Wiring connector
Old Jan 1, 2012 | 05:59 PM
Tee Bagger's Avatar
Tee Bagger
Default Help!! Wiring connector
Putting on primeapes...bars are on, plugging connectors back together and the black connector for the right side controls won't snap together. It needs to go in about
3/16"more. The white piece thats inside the connector won't go in all the way. The pins look like there all in correctly...what could be holding me up??
Old Jan 1, 2012 | 06:02 PM
steelhead's Avatar
steelhead
Sometimes you will bend a pin pulling it though the bars. I would make sure everything is matching up when they come through the white holes. If not, pull that one and straighten. You can also take needlenose and pull up gently on each pin before you seat the white inner sleeve to lock it.
Old Jan 1, 2012 | 06:05 PM
Tee Bagger's Avatar
Tee Bagger
The pins look fine, it's the white part..it will only go down about half of what it should. Is there anything else that could be holding it up.
Old Jan 1, 2012 | 08:07 PM
Tee Bagger's Avatar
Tee Bagger
Had to push each pin in...one at a time...then the white piece went in the extra little bit. Had no issues with the other connectors...not sure why this plug was being so difficult.
Terminator69
Apr 28, 2015 12:02 PM
Terminator69
Electrical/Lighting/Alarm
Apr 28, 2015 10:19 AM
Granpita
EVO
Nov 6, 2014 06:16 PM
Bruin08
Oct 15, 2014 05:01 PM
Munkee
Audio Systems
43
Aug 16, 2014 12:22 AM
