Chrome brake rotors
Old Jan 3, 2012 | 08:59 AM
speedracer's Avatar
speedracer
Default Chrome brake rotors
I was wondering how well the chrome 1 piece rotors work on the touring bikes. Does the chrome area that makes contact with the pads start to look bad after a while???
or is a 2 piece rotor the way to go???
Thanks
Old Jan 3, 2012 | 09:11 AM
07FLHT's Avatar
07FLHT
One peice rotors are not chrome, they are polished. Pad contact area is gonna scuff the first time you hit the brakes.
Old Jan 3, 2012 | 09:53 AM
hatchetman's Avatar
hatchetman
Make sure your new rotors have holes on the contact surfaces to displace water!
Hatch.
Old Jan 3, 2012 | 10:14 AM
grbrown's Avatar
grbrown
Thanks
Do you want to stop?! If you want chrome, go with 2-piece. You can see what happens on normal rotors where the pads rub and the chrome on one-piece rotors will quickly go the same way.
When disc brakes first came out on bikes in the 70s, some brands (Triumph IIRC) used chrome plate. Not only did they not stop very well, eventually the chrome started to peel off, which is also not good!
Old Jan 3, 2012 | 10:55 AM
Damascus's Avatar
Damascus
Harley offers a range of semi-floating rotors with chrome centers. These have serve me well up front. Out back, you can't see the rotor on my bagger RK anyway so I left it stock.
Old Jan 3, 2012 | 11:33 AM
qtrracer's Avatar
qtrracer
Thumbs up
Believe or not a few years back(the 90's) PM was making cast iron rotors flash chromed(or nickle plated I can't remember), the plating wore off where the pads made contact very quickly by design. You had to pull the pads after the plating wore off and sand them on a surface plate, but after that, Whoa daddy! The plating still was on the rest of the rotor to keep the surface rust in check.
Old May 14, 2024 | 01:14 PM
oleksa's Avatar
oleksa
how well these rotors served?
Old May 14, 2024 | 01:16 PM
Keithhu's Avatar
Keithhu
12 year old thread and he hasn't been on the site for 2 years, just setting expectations for a response.
Old May 15, 2024 | 07:17 AM
Sethc1020's Avatar
Sethc1020
Polished 1 piece rotors are great, you just have to buy organic brake pads so they don't scuff. I've had some for several years now and they still look great.
Old May 15, 2024 | 07:22 AM
oleksa's Avatar
oleksa
Thank you for reply and for the organic pads advice in particular. About to order pair of polished.
