I just changed out my bars today and my brake line is about 3/4" too short. Do they make an extention that can thread into the master cylinder to make up this. It would be male on one side to screw into the M/C and female on the other to accept the banjo bolt. Thanks for any input.
Don't know of any way to extend a brake line. Seriously, how did you figure out it's 3/4 inch short? Unless it's stainless you should be able to get a longer line for $30.
there is a company in Rowley.Ma. called 4R CUSTOMS that makes wires and cables,they do custom work..do a ebay search for handle bar extention kits and they will come up
If you are talking about the 2002 in your sig, I just went through this with my 2003 FLHRCI when I changed bars. I went down to the dealer, went through their Drag Specialties catalog, looking for a "Stock +2" brake line. It seems that the junction block under the tripple tree (on mine) was different than anything they had in the catalog. I forgot which was which (too cold to go out and look), but what was on my bike was female and the lines were male (or the other way around, again - I forgot which).
Anyway, instead of a $40 upper brake line, I ended up getting the "kit", upper, 2x lowers, and a new junction block. Set me back about $150.
Long story but, no I have never seen an "extender" for brake lines, and I'm not sure that I would want one. Spend a few bucks and do it right.
Reason: Having a bad spelling day...
I guess i`ll look into a 2+ upper. I wasn`t really looking to legnthen the brake line rather extend the master cylinder hole out 3/4.
Thanks for the suggestions
