Blowing through rear brake pads
Old Jan 3, 2012 | 11:03 PM
bmaier's Avatar
bmaier
Ive got 33K on my orginal front and rear pads, 09 Ultra, still quite a bit of left before hitting wear indicators but I do get some squealing/noise on my rear caliper
Old Jan 4, 2012 | 05:46 AM
GLACIERPEARL's Avatar
GLACIERPEARL
I probably only touch the rear brake peddle once every thousand miles or so.
I'm kind of a grandpa behind the handlebars, and rarely , if ever, find myself in a situation that calls for rear brakes to be used.
I doubt I'll ever wear out a set !!
Old Jan 4, 2012 | 06:17 AM
leafman60's Avatar
leafman60
No disrespect but you are probably favoring your rear brake much too much.
This is a common trait among cruiser riders. Experiment more with the front. The front does most of the stopping. It is where your weight distribution shifts while stopping and it is where you have all your stopping traction.
Sure, you need a rear brake. Under high speed stops, you trail it to keep the rear end behind you. Also, in parking lots or in slow speed situations on loose surfaces, gravel etc., the rear comes in handy.
I would think you should get 20k-plus on your rear brakes depending on your riding conditions.
Be careful out there !
Old Jan 4, 2012 | 06:32 AM
Sandcrab's Avatar
Sandcrab
Default Almost 20K
2009 Ultra with ABS and 19,500 miles on original pads. Have never removed the calipers but did check for the wear grooves, and they are still OK. Not sure how to extrapolate that into when to change however.
Old Jan 4, 2012 | 06:47 AM
leafman60's Avatar
leafman60
Sounds like you are doing good ! Were you a sport bike rider ? Honda CBR ? Kaw Ninja ?
Just look at the pads every once in a while. Looks like you may get 40k on your pads.
Old Jan 4, 2012 | 08:04 AM
jberg's Avatar
jberg
If you use the method described in the Ride Like A Pro videos then you'd be using your rear brakes alot during low speed maneuvers. Rear brake pads are relatively cheap and easy to install. I usually throw in a new set with each rear tire change. It's no big deal and it allows you to control that big bike at very low speeds.
Old Jan 4, 2012 | 09:01 AM
PerformanceFrictionBrakes's Avatar
Former Sponsor
Default PFC Brake Pads
I can recommend Performance Friction Brake Pads which are the longest lasting on the market. No wonder we are the prime choice for top leading fleet vehicle brands and Race Teams. Good Initial and Modulation. No Dust. No Noise. Used on Police Bikes.
www.performancefriction.com
704-402-4991
Old Jan 4, 2012 | 09:39 AM
69z28's Avatar
69z28
Got 19k on my 10 Ultra and they still have a lot left on them.
Old Jan 4, 2012 | 10:59 AM
PNSHVL's Avatar
PNSHVL
Same here with my 2006 FLTRI.
cochon
Mar 17, 2016 06:06 PM
Rollbar
Feb 3, 2015 07:29 PM
Mike650
Mar 6, 2013 10:40 PM
Scrmnvtwins
Aug 23, 2012 03:08 PM
1st 96 ultra
Jun 11, 2011 11:59 AM
