PBR 300x2 Amp Install Problem?
Old Sep 6, 2012 | 08:43 PM
UltraNutZ's Avatar
UltraNutZ
Goodboo. Don't think about it too much or you'll scare yourself. Just dig in and do it. My recommendation is;
1. pull the fuel tank off and get it out of the way. it's easy to take off and put back on
2. there is a plastic wire tray under the fuel tank, pop the top off of it and use that tray for your wires. Makes for a very clean install.
3. sitting on the bike, to the left front of the wire tray is a rubber sheathing with wires going through it for the fairing. Take some WD-40, spray inside that sheathing, and your power wires will slip right through them keeping all wiring concealed.
I am VERY **** about wires. I hate to see them, period! I'll spend an extra hour running wires before I allow 1 single wire to show on anything I do. but that's just me.
the rest of it is easy.
Old Jan 18, 2015 | 04:25 PM
CHEROKEE CHIEF's Avatar
CHEROKEE CHIEF
3rd Gear
I am reading the box it is apbr 300x2 dated 08/26/14. I can't get the radio to cut off with the switch. If I pull the fuse from the amp it goes off.
Old Jan 18, 2015 | 10:15 PM
CHEROKEE CHIEF
3rd Gear
I figured it out. Thanks anyway
Old Jan 18, 2015 | 10:17 PM
SBates08's Avatar
SBates08
Ok so what was it?
2010 Limited with some stuff!!
kevnsteph2016sg
Audio Systems
May 2, 2018 10:12 AM
nthere1
Jun 14, 2015 09:57 PM
D RENEGADES
Audio Systems
Feb 28, 2014 12:27 PM
Ryder7140
Audio Systems
Jun 1, 2013 05:13 PM
marvincbr
Audio Systems
20
May 6, 2013 06:03 PM
