How low with monotubes?
Old Jan 6, 2012 | 03:41 PM
sublime_ac's Avatar
sublime_ac
I lowered mine 2" with the mono tubes...
Ride much better than stock.
Old Jan 6, 2012 | 06:14 PM
dbell66253's Avatar
dbell66253
Progessive monotubes -2" here, night and day difference from stock.
Old Mar 4, 2012 | 01:23 PM
Nozzleman 216's Avatar
Nozzleman 216
I don't have my 21 yet (may go 23) but I am putting installing monotubes now since I am powder coating my forks. I was told by progressive that I could use ONE c-clip with a 2 inch lower even though the instructions say not to use any. They said for my weight (220) and 2-up riding that it would work.
Did either of you use a clip or have you read or heard of anyone doing it?
Old Mar 4, 2012 | 07:16 PM
UltraDune's Avatar
UltraDune
Here is a question for you guys running the monotubes. I have asked at my dealer and others and nobody really seems to know. I have a 2011 RGC, have put 1" longer shocks on the back and am getting ready to do chrome front end and standard height monotubes. I want to go with a 21" front wheel. Will my bike be Ok with the 1" longer rear shocks and the monotubes at standard height? I was told that the monos drop it about 1/2". Any thoughts? Thanks.
Old Mar 4, 2012 | 07:44 PM
Nozzleman 216
I am definitely not an expert on this, but from what I have read the 21 will raise the front some. I am not sure about the standard monotubes, but I think even if they lowered the bike a little, you would still end up riding just like you are now (about stock height) once you combine the shocks and wheel.
Old Mar 4, 2012 | 10:43 PM
sublime_ac's Avatar
sublime_ac
If you put a twenty one on it raises the front about an inch and a half. That is why I lowered mine..
If you go with a 23 you will want to adjust the rake of your bike.. The cheap way is with triglide triple trees... If you do that you will not need to lower the suspension because the additional rake will get things l inked back up... But.. Then you need to get your headlight back in line etc.. As well.. More to think about.
Old Mar 5, 2012 | 11:42 AM
Nozzleman 216
Headlights not an issue with Road Glide
I will probably just do a 21. They look good enough with the lowered front end. Now just to decide if I need a c-clip or not. I am leaning towards not right now.
Old Mar 5, 2012 | 01:35 PM
Polcat19's Avatar
Polcat19
Stage IV
I run progressive front and rear.
Monotube with 2" drop in the front does make it stiffer. there is vibration in the bars. You feel every little bump, not bad, but you know they are there.
I wish I would have gone with only 1":
-it would give some rake to the bike as a whole with my 19" wheel
-I could really lean into turns. I scrape the exhaust now (my only true dislike) but the suspension holds like mad.
Old Mar 5, 2012 | 10:10 PM
davedyna's Avatar
davedyna
Hi king,
The friction to the handlebars may be construed as a rougher ride. Is that what is suggested. I personally am considering them for brake dive but wondered if I trade off vibration in the handlebar.
Thanks
Dave
FireFighter200
2014-2024 Touring Models
Mar 22, 2017 09:37 PM
badger3x
Oct 28, 2014 09:04 AM
brandss
May 8, 2013 07:05 AM
bbs15
Oct 25, 2011 06:27 AM
drewski1325
Nov 10, 2009 08:08 PM
