Plasma Rods
Old Jan 26, 2012 | 12:15 PM
luisan's Avatar
luisan
I didn't have them put on yet by my mechanic since I'm waiting for a replacement of my front LED turn signals from CustomDynamics,wrong base doesn't fit the socket in the turn signal housing,it might take some time to get them shipped to me overseas.I'll post pictures when done.
Old Jan 26, 2012 | 06:00 PM
Overdoo's Avatar
Overdoo
Default Equalizer module
[QUOTE=papifun;9307053]
Originally Posted by viperr817
Viper - can you post a few photos of the Plasma's installed at different angles pls..im lookin to wire just for break lights.. wondering if i still need to put an equalizer if tapped into the brake on wire...
No equalizer need if you tap in at the fuse box.
Old Jan 31, 2012 | 08:04 PM
toby34's Avatar
toby34
this is my setup only used for turn signal
Old Jan 31, 2012 | 08:13 PM
papifun's Avatar
papifun
toby.. can you take a photo without the saddle bags.. i want to see how you mounted the Plasma Rods... I am looking just to add the rods for brake lights and wondering if i can get away without using an equalizer...
Old Jan 31, 2012 | 08:26 PM
HDV-GLIDE's Avatar
HDV-GLIDE
You can, only need the equalizer if you add LED turn signals.
Old Feb 1, 2012 | 06:35 AM
toby34's Avatar
toby34
I used 3m automotive two side tape and mounted them to the side of the fender. Badlands makes the very best in eq for this and all applications. Call them and tell them what you are using and they will send you what you need to make your setup work
dab102999
Electrical/Lighting/Alarm
Nov 8, 2018 07:47 PM
paulies 07
Mar 28, 2013 08:42 PM
bikehunter
Jun 24, 2012 07:49 AM
klinker24
Oct 5, 2008 08:59 PM
Slayer
Mar 20, 2007 11:24 AM
