Which Compensator to get?
Old Jan 11, 2012 | 01:44 PM
fabrik8r's Avatar
fabrik8r
Originally Posted by dstrat1
I put on the SE and there was no requirement to balance it. It was a big improvement over stock....If you are taking the time to open it up why put the stocker back in, it has a history of problems...just getting rid of the starter clunk was worth the swap and it runs way smoother..JMHO
Not required, just a helpful hint from a man who spent his life building performance Harleys. Every little bit helps, any rotating component will benefit from balancing, doesn't mean its a requirement.
Old Jan 11, 2012 | 01:45 PM
Eric Moore's Avatar
Eric Moore
will this issues ever end..i have the S/E parts waiting to install just havent worked it in yet......
Old Jan 11, 2012 | 02:06 PM
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
Originally Posted by X Iron Butt
I fixed my compensator "BANG" ...
I wouldn't mind having a brushless servo motor instead of the traditional serial wound starter motor. This type of motor can eliminate the initial "Bang", spin fast enough to start of the engine progressively and then charge the battery once the engine is running, like on a hybrid vehicle.
Old Jan 11, 2012 | 02:25 PM
2004Sierra's Avatar
2004Sierra
If you think you have a problem with your compensator be sure and find the root cause of the problem. I fixed my compensator "BANG" with a $79 All ***** starter clutch and a few hours of learning a new starter system in my garage (see my album). With some of the newer posts on here it still doesn't sound like the MOCO has "FIXED" the compensator. Now there is a question of balancing the new $250 compensator. And that still doesnt fix the not enough oil issue they are having. Might want to wait a bit if you can.
The bang I and most have had at startup is not caused by the starter.
The stock compensator is weak. When you engage the starter with the engine on the compression stroke the compensator will bottom out with a loud metallic bang.
The starter motor run-up, and sudden impact when the comp bottoms out will eventually kill a starter drive clutch.
I am extremely satisfied with the SE compensator upgrade.
Old Jan 11, 2012 | 02:58 PM
Expat1's Avatar
Expat1
I think the stock compensator was designed to let the "Bang" protect the starter motor in case of engine misfiring due to a timing error. If the compensator springs are weak enough, once the engine runs under partial load the cams will no longer slide and will not wear their ramps.
Old Jan 11, 2012 | 03:59 PM
X Iron Butt's Avatar
X Iron Butt
All I am saying to the OP is be sure and find root cause. Obviousley this "BANG" can happen from different causes and just randomly replacing it is not the solution. IMO I don't see how starter run up could possibly have a "BANG" as prominent as mine was. Your springs must have been non existant. But that would not surprise me. At 37K miles mine definitely came at comp unload as the engine started. If it didn't start it did not bang.
I also am not trying to offend anyone who did the upgrade or saying they made a bad decision but based on postings on this forum including this thread I would wait if it was not an imediate problem. Just me I hate fixing something that doesnt get fixed especially when this kind of money is involved or someone comes out with a better moustrap the day after I bought mine (Like the A version of the SE). When the MOCO comes out with the B version to fix the fretting in rotating parts I might consider an SE and thought the OP might like to know about those issues.
Old Jan 11, 2012 | 04:41 PM
2004Sierra's Avatar
2004Sierra
No sir, no offense taken...
The starter run up issue is what I was told by a very knowledgeable HD tech.
It made sense to me that is what was happening in my case.
The bike would never start when it banged, never. It would bang right when you hit the starter and then a puff of smoke out of the air filter when the engine backed up. Same sequence every time, bang then smoke out of the intake.
The tech told me the weak spring system of the comp was the problem.
Since replacing with the SE comp I have no more bang at startup. It fixed it in my case.
Old Jan 11, 2012 | 04:49 PM
Punjabi Rider's Avatar
Punjabi Rider
I have SE in my 07 UC since Jan,08 and 47K miles later haven't given me any problem,but that doesn't mean it's bullet proof.
Old Jan 11, 2012 | 05:32 PM
springer 03's Avatar
springer 03
The mysterious bang on start-up. Is it caused by the compensator or the starter clutch? I vote for the starter clutch, and after talking with numerous techs ( formerly known as bike mechanics), at four different dealerships about it they seem to agree. Most didn't even know about the S.E comp and 3 of the 4 dealerships had never seen a stock compensator go bad, or admit to it.
Old Jan 11, 2012 | 05:36 PM
springer 03
In addition they knew that the starter clutches were a piece of **** and could change them in no time. I think the main telling point is that none of the dealers stock the S.E. compensator ( special order item),but they all stock the starter drive clutch.
