Which Compensator to get?
Old Jan 10, 2012 | 12:34 PM
Spur56's Avatar
Spur56
Question Which Compensator to get?
Going to replace compensator sprocket on 2010 UC. Trying to decide between the SE or the BDL. Any thoughts on which one to get?
Thanks
Spur
Old Jan 11, 2012 | 02:32 AM
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
Thanks
Spur
How about simply inspecting the original compensator and putting it back together if its still OK? Unfortunately if you need to change the spring washers they come assembled with the rotor of the alternator #40356-07.
Old Jan 11, 2012 | 05:59 AM
DRAGO'S BIKE WORKS's Avatar
DRAGO'S BIKE WORKS
Former Sponsor
Talking
I can not speak for the BDL but the SE is a good one. Just make sure you send it out for balancing it will help with some of the added vibration we have found installing them and it will lighten it up a little. Since they are heavier than stock. I hope this helps
Thanks
Spur
Old Jan 11, 2012 | 10:27 AM
X Iron Butt's Avatar
X Iron Butt
If you think you have a problem with your compensator be sure and find the root cause of the problem. I fixed my compensator "BANG" with a $79 All ***** starter clutch and a few hours of learning a new starter system in my garage (see my album). With some of the newer posts on here it still doesn't sound like the MOCO has "FIXED" the compensator. Now there is a question of balancing the new $250 compensator. And that still doesnt fix the not enough oil issue they are having. Might want to wait a bit if you can.
Old Jan 11, 2012 | 11:18 AM
Spur56's Avatar
Spur56
Thanks Y'all,
This balancing thing is interesting. Who does that kind of work? I live near Chattanooga, TN and would not know where to take something like that for balancing. I an assuming a machine shop.
Old Jan 11, 2012 | 11:49 AM
69cj's Avatar
69cj
I installed the se comp. in my 07 rk and don't have a balance problem. 1st time I've heard of this issue.
Old Jan 11, 2012 | 12:22 PM
lionsm13's Avatar
lionsm13
Subscribed..
Old Jan 11, 2012 | 12:39 PM
Turbo Turtle's Avatar
Turbo Turtle
The 20 yr factory trained mechanic I know here said we would just take mine apart, clean it up and re install it. He had nothing good to say about the SE # save for the remark that it might last just a bit longer. So I'll either do that or go with the Baker.
My $0.02
aka Bob
Old Jan 11, 2012 | 01:21 PM
dbell66253's Avatar
dbell66253
Frank this is the first time I've heard of having to balance a compensator, where would you suggest getting this done?
Old Jan 11, 2012 | 01:31 PM
dstrat1's Avatar
dstrat1
I put on the SE and there was no requirement to balance it. It was a big improvement over stock....If you are taking the time to open it up why put the stocker back in, it has a history of problems...just getting rid of the starter clunk was worth the swap and it runs way smoother..JMHO
