looking for someone who has taken a touring (ultra) windshield and cut it down.I am going to try this with one I picked up but unsure what the best way would be to do it.what tools would I need? thanks
hi use a piece cardboard draw the bottom of shield on it be sure you are square cut card board with scissor if you want 2.. short just raise board cut jigsaw with steel blade marc
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
I once used a belt sander to slowly grind down the edge of a windshield. The trick was to keep the windshield aligned better than 10 degrees with the track of the belt to avoid vibration. Then use the back of a knife to remove the lateral burrs, a fine toothed wide flat file filled with chalk to make the curved chamfer along the edge and finally a grade 600 wet sanding paper to get the satin finish. Never abrade plastic with less than 5 teeth of a file or grains of abrasive engaged over the material. You can also use porc fat on the sanding paper to avoid burning scars into the plastic. I used silverware polish to finish the job
