Extra wires on Zumo 660 Harness???
Old Jan 14, 2012 | 10:19 AM
Talldog's Avatar
Talldog
Default Extra wires on Zumo 660 Harness???
Hey guys, am installing my Zumo 660 today.
On the wiring harness, there are a total of 5-wires. I know that the Red/Black is power/ground.
The other three are a Female mini-USB, and two Female round connectors(kinda like for a MP3 plug).
The instructions don't mention anything about these three mystery wires.
I'm assuming they're for if you're going to install the separate Navigation Interface so the GPS will "talk" to the radio(which I'm not installing).
So, I'm thinking that I can just coil these three extra wires and Zip-Tie them somewhere inside the Fairing, but wanted to double check before I re-install the outer Fairing.
Thanks
Old Jan 14, 2012 | 10:31 AM
vzts4q's Avatar
vzts4q
Thanks
Think that info is in the Garmin manual But Google got this.
Microphone 2.5 mm
Headphone 3.5 mm
mini usb traffic receiver
http://www.google.com/url?sa=t&rct=j...4pxmtw&cad=rja
Old Jan 14, 2012 | 11:27 AM
Talldog's Avatar
Talldog
Microphone 2.5 mm
Headphone 3.5 mm
Thanks, exactly what I needed. Those instructions for the standard 660 are better than Harley Provides for the Road Tech 660.
Old Jan 14, 2012 | 04:01 PM
papifun's Avatar
papifun
i tie wraped the USB and microphone in the fairing.. i did tie wrap the headphone wire onto the handle bar and plug it into the HK radio 3.5mm input when i want to here the GPS on the radio. my mufflers dont make it easy to here the GPS with the internal 660 speaker.. you would wonder why HD doesnt add bluetooth the the HK radio,.. would save all these cables ... ride safe.
Old Jan 14, 2012 | 04:03 PM
nivensid's Avatar
nivensid
Microphone 2.5 mm
Headphone 3.5 mm
The mini USB is when you download from the computer which is useless because it is on the bike and mounted behind the fairing in my case. Use the 3.5 mm is the audio out to your radio.
Old Jan 14, 2012 | 05:52 PM
vzts4q's Avatar
vzts4q
I copied the information from the Garmin instructions.
The Mini usb in the wiring harness is for a traffic receiver as is stated in the instructions in the link I posted. And has nothing to do with the mini usb an the 660 itself.
Gonzy
Nov 11, 2012 10:01 AM
MOroadking
Audio Systems
Jul 8, 2012 03:59 PM
alandchris
Jan 18, 2009 07:22 AM
Ohio HD Guy
Sep 20, 2008 01:06 PM
leeinmemphis
Feb 28, 2008 12:53 PM
