xied
Old Jan 15, 2012 | 06:11 PM
speedwaysteve's Avatar
speedwaysteve
Tks thats pretty much what i am lookin for
Old Jan 15, 2012 | 06:19 PM
Ronp42's Avatar
Ronp42
Account Retired
Originally Posted by mkguitar
I have an 09 FLHTC.
96" ness air cleaner, stock no cat headers, hi flow supertrapps.
In completely stock form the motor would ping on 6% grades between 2800~3200 rpm- the xieds solved that.
Once that was solved I went to hi flow air cleaner and the supertrapps ( which I use on a number of bikes).
Many thousands of miles of good operation, MPG at 43 MPG ( was 44 MPG before Xieds)
Mike
Erased post
Old Jan 15, 2012 | 08:40 PM
speakerfritz's Avatar
speakerfritz
Originally Posted by Pine Tree
What makes you think a little fattening is needed? Where in the map does it need the extra fuel? How much extra fuel does it need?
Good luck!
your kidding right.....or you are driving a pre-07 bike possibly????
Old Jan 16, 2012 | 07:30 AM
Pine Tree's Avatar
Pine Tree
MODERATOR
No to both questions...had an '08 UC and now have a '12 UC.
So yes, I'm familiar with the HD EFI system, "ied's" as well as their variants, and tuning in general.
The OP seems to suggest he needs additional fueling because
Originally Posted by speedwaysteve
...ive pulled the plugs they arent to bad..look a lil on the lean side
Apparently he's under the impression that just adding fuel pretty much across the map will make the plugs look "a lil on the rich side.." and thus better.
If he simply wants the plugs to look richer, all he needs to do is either increase or decrease the plug gap enough to cause them fire less efficiently. Both ways will normally cause the plug to collect carbon and thus look richer and won't cost a single penny.
If he has reasons beyond "rich-looking" plugs, then I strongly stick by my first post.
Old Jan 16, 2012 | 07:46 AM
blockzilla's Avatar
blockzilla
here we go again .............
prufrock28
Sep 21, 2010 02:14 AM
SteveinNKC
Sep 20, 2010 09:02 PM
ballbreaker69
Aug 22, 2010 06:20 PM
hydrolock43
Jun 11, 2010 09:48 AM
hydrolock43
Apr 9, 2010 06:28 AM
