THE 103 KIT was already installed when I bought the bike used it had 8500 miles on it. It now has 26,000 on it and I don't know what has all been done but i think it is all stock except for the 103 and air cleaner I had a power commander put on it. woods tw555 have been recommended,. Wondering if this is a good choice? not really looking for a tire smoker just want to get up the hill
just to let you know, if you go with the woods you can't use the original push rods...you have to go with adjustable ones...
You want to get "up the hill" with your set up? SE255 would work. I have a 103 with rineharts and heavy breather running a S&S 551. I reused the stock pushrods and all is well. My set up will definitely get you "up the hill" as would the SE255. You appear to need a torque cam. You can tell that everyone has their favorite. Any good torque cam should get you what you want.
As I mentioned in a previous thread this bike uses the SE255 cams too.
When you did the big bore kit, did you change to a mls head gasket? Did you do a deck check or cc your chambers? With the heads off, I would be looking to equalize the chambers and bump the compression just a little, which can have a significant impact on which cams you will choose. I would not assume you have the same compression as an otherwise stock 103er.
Good advice. There are several cams that will work, some have been mentioned and others have not. Andrews 48, TMan has several, S&S has several, etc. Throwing in a set of cams without knowing certain facts, like chamber volume, deck height and head gasket thickness is not a good idea. The factory tolerances on TC engines vary and can result in varying results, some good some not so good. As an example, the pistons in the later TC96s are down in the cylinder more than the early TC88s; not an absolute but that's what most are seeing. Chamber volume is supposed to be between 85cc-86cc but I have seen the measure more than 89cc. The chamber volume can vary from one to the other and the uneven combustion can cause on engine to shake more than another. Measuring and re-setting these variables is akin to "blue printing" but the attention to detail will make a difference in the outcome. Cam base circles also vary and may require the use of adjutable pushrods.
Once you have the data, you can choose from a variety of cams that will work. Getting the compression right for the selected cams is important. Much of the performance gain from installing a set of cams with the correct compression can be attributed to the increase in compression, not the cams themselves.
