gps for flhrc
Old Feb 3, 2012 | 06:32 AM
mrfikser's Avatar
mrfikser
Default gps for flhrc
I have a 11 flhrc and I am researching putting a gps on it..right now I have a tomtom and while it is easy to use, I can't see the screen in the bight sun....Sooo, I am thinking maybe a zumo, ...any advise for you all on what is good and not good will be taken into account before I buy..also this will be a handlebar mounted unit, which I believe is different then the full dressers, so I need to take that into account, also any info on good/ better handlebar mounts would be appreciated...
Old Feb 3, 2012 | 09:18 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
most zummos come with a good handlebar (or clutch perch )mount.i use the 450 for 5 years it died got a 550 refurb for 140$ to replace,both good units easy to see in most sun,only bad in full on direct. there also a bunch of aftermarket mounts available as well.
Old Feb 4, 2012 | 08:16 AM
mrfikser's Avatar
mrfikser
thanks...any ideas on where to purchase one??
Old Feb 4, 2012 | 08:49 AM
DanDolfn's Avatar
DanDolfn
I have a Garmin 1450 with a RAM mount.
It's a good combination.
Old Feb 4, 2012 | 12:40 PM
Arizona's Avatar
Arizona
Same here, 1450 Garmin Nuvi, works great, big easy to read screen and not too expensive.
Old Feb 4, 2012 | 12:59 PM
Guntoter's Avatar
Guntoter
The Zumo is waterproof, most of the others are not. So keep that in mind, unless you don't mind throwing a ziplock bag over it in the rain.
Here is the best mount I have found for the GPS. It mounts right under your mirror stalk.
http://www.ram-mount.com/CatalogResu...5/Default.aspx
Old Feb 4, 2012 | 01:43 PM
mrfikser's Avatar
mrfikser
how does the brightness of the zumo in sunlight compare to the garmin and does the garmin charge the battery when it is plugged into the computer??? I ask because my bike is already wired for usb on the handlebars and hopefully I will be able to just plug the garmin into the usb plug on the handlebars to charge it....whereas the zumo has a special mount that is only good for the zumo....
Old Feb 4, 2012 | 02:55 PM
bigdumbnoitall00
zummo and nuvi are both garmin,all zummo are designed for bikes,many nuvis will work fine at a better price,the only nuvi i know is water proof is the 500 or 550,the zummo is easier to see in sun.and i know the zummos charge on usb,not sure on nuvis but think so.
Old Feb 4, 2012 | 03:43 PM
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
I use the Garmin 62st. It's waterproof, has great readability under direct sunlight and runs around 30 hours on it's two cells.
A few days ago my cheap asian power supply died at noon because of heat and sea water but I had plenty of battery power left to reach destination. Rinse the unit under tap water and it's ready for the next day. This is really a versatile unit and a worthy investment.
Old Feb 4, 2012 | 08:23 PM
DLIMITED's Avatar
DLIMITED
Nuvi will charge by USB works great but cannot see during sunlight thats when I hook up to radio to hear directions I use the ram mount with power supply hooked inside the faring...
