Need help finding post
Old Feb 4, 2012 | 12:12 PM
Tonhick's Avatar
Tonhick
Default Need help finding post
In a post here there was a comparison of red/green power light for Hogtunes amp. Have been looking for 2 days now to find it again. Please help.
Old Feb 4, 2012 | 12:27 PM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
Try doing a search.
Old Feb 4, 2012 | 12:29 PM
mkguitar's Avatar
mkguitar
I tried a forum search for you, but no luck- the site can get pretty jammed up on weekends
I got database errors.
when trying:
hogtunes red green
keep trying
mike
hawwk's Avatar
hawwk
Try going right to the hog tunes web site
Old Feb 4, 2012 | 12:31 PM
dawg's Avatar
dawg
Trying to search on here now gives me 404 errors. The search feature here has been sucking lately.
Old Feb 4, 2012 | 12:33 PM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
Ditto. Search locked up.
Old Feb 4, 2012 | 01:23 PM
X Iron Butt's Avatar
X Iron Butt
The green power light is the latest revision from HT. Some amps on some bikes had problems out of the box due to low voltage @ amp on start up. HT would repair for free but it was a PITA to do two installs with ship and repair time in between. The problem would cause front or rear or both speakers to fail to come on without doing several off on sequences and there was no set pattern to when / if it would happen. I think the new green lamp versions are set up to allow less than 7 volts @ power up. If you install per supplied harness the amp powers off of the cig lighter. This is hot (amp on) whenever the key switch is in the on or acc position.
Old Feb 4, 2012 | 04:15 PM
Tonhick's Avatar
Tonhick
Thanks for the info....The hogtunes website has been down for the last couple of days also....Have bought a used 24.2 amp w/red pwr lite to power 7W lower woofers a new 40.4 amp for the front, w/tweeter bar and rear speakers...Will be installing before spring and would like to only do it once....Will contact HTunes first of week and ask about the fix before installation....thanks again....
Old Feb 4, 2012 | 05:08 PM
Ron750's Avatar
Ron750
Even when search is working you're sometimes better off using Google. This search will give you every thread that even uses your search word one time.
If you can remember a couple of search words Google will probably work better than HDF search.
Old Feb 4, 2012 | 05:14 PM
vtwinbob's Avatar
vtwinbob
try this one it might help, don't know for sure. https://www.hdforums.com/forum/touri...oom-audio.html
