Awesome looking machine,it look like best of worlds to me. Have you determined how much it weighs with the stuff you added. I think the name of it should be "dyna ultra". You should be an engineer for Harley.
Riich believe it or not it doesnt handle any different to me than it did stock so i must have done something right. I also just got done adding some rear speakers to go put some tunes back there for the OL. I need to add a small amp to boost the power a little if some one can turn me on to one that i can mount inside the fairing?? Here are some pics from that project if anyone is interested-
Cut a hole to mount the 6 1/2 speaker on the inside(toward the tire) for the stealth look-you actually cant see them unless you look for them.
Here it is mounted in saddlebag-i just used some el-cheap-o's for know to get it going-going to get some good marine grade later.
A look on the inside-i also sprayed the inside of the bags and tour-pak with sound eliminator rubberized coating so they wouldnt have the hollow sound.
Once i got speaker wire ran up to fairing there wasnt a place to run them inside to the head unit so i went to autoparts store and got some rubber grommetts and had to drill a hole in fairing and i put in the grommett to run the wires through.
Heres a closeup-sorry for the crappy pic. anyway guys like i said if anyone can give me some info on a good amp to go inside fairing i would greatly appreciate it. Peace-be safe and ride HARD. thanks for all the comments!!!
Excellent work on your Dyna. I really like your ingenuity in developing your bike into what you want it to be. There's a lot of satisfaction in doing that.
I think that the Dyna forum has some really cool bikes - I visit over there often
You belong wherever you feel comfortable - Keep us advised on your progress
